linn kelektor power supply
did you find a circuit diagram for this preamp I have similar problem with the power supply, found two capacitors open circuit but I suspect the zeners as they don't look right when testing in circuit there are two z3 is a ph od 0c3v 12 but z2 I cant this out at all will take them out and test properly
