Passive pre amp - 50k or 100k pot?
Old 24th March 2020, 11:31 AM   #11
sgrossklass is offline sgrossklass  Germany
Originally Posted by rsavas View Post
On the bjt IPS example, say with a unipolar input and not complementary with some degree of bias current cancelation, is the base bias current not isolated by the input coupling cap?
DC - yes.
AC - no.
Any dynamic cancellation of input bias current nonlinearity requires matched impedances.
If you look at Samuel Groner's measurements of BJT input opamps, the input bias current related effect shows up as the flat area at lower frequencies in the input impedance distortion graph; higher up, input impedance starts to dominate.
Their JFET colleagues show almost none of that shelf (it is eventually limited by common-mode distortion) but the capacitive part tends to be stronger by about a factor of 3, with very few exceptions like the OPA627 and its bootstrapped cascode input.
Old 24th March 2020, 11:34 AM   #12
adason is offline adason  United States
adason's Avatar
Originally Posted by Asterix2k10 View Post
I built a passive pre amp with a 100k ohm pot - should I have used a 50k instead?
25k
  Reply to this post
Passive pre amp - 50k or 100k pot?Hide this!Advertise here!
10k pot vs 100k pot edwtsui Parts 9 30th July 2018 03:27 PM
$2.50 each 100 qty 100K log/100K anti-log potentiometers available mrbutterskin Swap Meet 1 6th February 2014 11:35 PM
EL-34 and 100k pot podboy Tubes / Valves 1 26th June 2007 11:49 PM
50K vs 100K POT ss1 Parts 7 22nd July 2004 12:57 PM
50K or 100K pot? 2Bak Chip Amps 14 9th November 2003 02:25 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
