Active audio divider with LME49720 Dual
Old 25th January 2020, 04:07 PM   #1
MilanAudio is offline MilanAudio  Czech Republic
MilanAudio's Avatar
Question Active audio divider with LME49720 Dual
Hello to all,
I am working on audio divider using LME49720 Dual op amp. I am not experienced with making design dedicated to some op amp, but I guess there should be some resistor and at least one cap.
Any idea what resistors should be used? Or what should be added?
Thanks for help!
Milan
PS: I did some googling but some dividers has feedback resistor, some not... I am confused
I've done this... and the same will be for R ch. as I want dedicate 1 dual op amp to one channel because of separation.
Datasheet: http://www.ti.com/lit/ds/symlink/lme49720.pdf
Old 25th January 2020, 04:50 PM   #2
Douglas Blake is offline Douglas Blake  Canada
Account Closed
If you are simply wanting 2 identical outputs, you've just about got it covered except for biasing the + inputs, there you will need a resistor to ground, typically 100k works fine.
If you want unity gain you can eliminate R1 and R2 and simply connect the - inputs to the output pin.
If you are after some gain you will need to add a resistor from each - input to ground. The gain would then be the ratio of the values of the resistors.
R3 should be set to match the impedance of the previous stage, although in practice it's not actually needed if the unit is permanently connected.
Old 25th January 2020, 05:55 PM   #3
MilanAudio's Avatar
Thank you, I hope I got it right...
No amplification, just two identical left channel outputs, most possible channel separation, this is why 1 LME will be for left channel and second one for right channel.
Here is edited version:
Old 25th January 2020, 06:02 PM   #4
as_audio is offline as_audio
R2 is not required.
Old 25th January 2020, 06:13 PM   #5
MilanAudio's Avatar
Originally Posted by as_audio View Post
R2 is not required.
So yes, the device will be connect permanently, but it might be working without input/load for short time...
the 1 pair LR will go to 1 amp, second pair will go to second amp.
So like this? Looks really simple more than I thought.
Old 25th January 2020, 06:17 PM   #6
You would call this splitter, not divider, I think.
Old 25th January 2020, 06:20 PM   #7
MilanAudio's Avatar
I think it's the same - split or divide, no? In other words - it should make from 1 left ch two left channels. And from 1 right channel two right channels.
I did googling and people are using the both words.
Off topic - grammar: To split something it to cause it to divide, usually using some type of force that causes it to break. When someone says "split" they are essentially using a different way to say "divide". A country divided into 5 parts and a country SPLIT into 5 parts is virtually the same thing, however, saying "a country split into 5 parts" is more like saying "a country (that has been) broken into 5 parts". In everyday conversation or simplified explanation, it is more informal and casual to say "split" instead of saying "divide", but something that has been split was probably divided by force or broken into parts. or 'Divide' might suggest a more equal distribution between the parts, and it may also suggest a more careful, thought-out action than 'split'.
Old 25th January 2020, 06:34 PM   #8
MilanAudio's Avatar
Back to circuit: is there something should be added please? isn't it too simple?
Old 25th January 2020, 07:05 PM   #9
Account Closed
If it is just feeding one pre-amp to two power amps, it's probably already too complex.
You don't actually need any electronics at all ... just a simple Y adaptor cord will do the job just fine.
In fact the cord might be better than your solution because a chunk of wire can't introduce hum, phase shift, crosstalk, distortion or propogation delays.
If you still want to go the active route... See the thumbnail (revisions in red)
Old 25th January 2020, 07:24 PM   #10
MilanAudio's Avatar
Thank you Douglas, so basically your attachment is like my last updated image:
I would like to have two pairs outputs because I would like to connected one to main amp which has build in preamp and second output to external sound card, or tapedeck, etc. (it dependent what I will be doing, what combinations). And yes, I want channel separation, minimum distortion and so on, the LME49720 has nice specs.
Active audio divider with LME49720 DualHide this!Advertise here!
Hum on DUAL 721 only when mute switch is active Rundmaus Analogue Source 11 21st March 2017 09:46 PM
Active 3way Dual AS 160 tower loudspeakers fixed. but... padamiecki Multi-Way 0 2nd September 2013 01:03 PM
dual opamp recommendations for active X-over? ByronInPortland Parts 5 2nd November 2011 01:06 PM
DIY Dual Channel Active Tube Tone Control HideawayStudio Tubes / Valves 1 1st November 2010 01:05 PM
FS: LME49720 Audio OpAmps zener_diode Swap Meet 2 17th February 2008 04:13 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
