SAE Preamplifier Equalizer Mark IXB
Old 14th November 2019, 12:37 AM   #11
rayma is online now rayma  United States
Originally Posted by audiomachines View Post
yes I did do the math, but you need to also know the DCR value of the inductor
so you could estimate the Q of the LC ckt
Measure the wire gauge, then calculate the coil resistance from the estimated wire length.
Old 14th November 2019, 06:54 PM   #12
llwhtt is offline llwhtt  United States
The Service Manual lists no inductor info other than the frequency that it is used.
Craig
Old 15th November 2019, 05:17 AM   #13
PRR is online now PRR  United States
PRR's Avatar
> DCR value of the inductor so you could estimate the Q
You know C and F, which gives L. Using F and either C or L you can compute Q. We don't know the design Q but if this is a 10-band I would start with 1.3 to 2.8. Comparison of peak boost to factory spec may refine this value.
Old 15th November 2019, 12:57 PM   #14
audiomachines is offline audiomachines  Philippines
Send a message via Yahoo to audiomachines
it is a 7 band eq with non ISO center freq 40hz, 120hz, 320hz, 960hz, 2500hz, 7500hz, 15khz i love the sound of inductor eqs similar to those manley passive eq, pultec amd rupert neve designs for me thisnis the real tone control before the simulated inductor become mainstream aka gyrators
Old 19th November 2019, 05:05 PM   #15
Rolox is offline Rolox
Hi all,
Anybody knows the inductor values of an SAE Preamp Mark IXB eq section? or service manual, I am currently restoring one and i am trying to wound my own coil using EPCOS P26 cores. Any info would be highly appreciated.Thank you.
I used to have a Mark 1B fully restored. Still regret having sold it
Old 27th November 2019, 05:47 PM   #16
If I hadn't blown up my LCR meter, forgot to discharge a capacitor, I would take my IXB apart and measure the inductors for you.
Craig
Old 29th November 2019, 03:09 AM   #17
Mark Tillotson is offline Mark Tillotson
Gyrators simulate ideal, linear inductors, which is a struggle for real inductors to achieve. I'd worry you think there's some magic present, when the magic is in the performance of gyrators, cheaper, better, more precise.
Old 29th November 2019, 11:14 PM   #18
My friend worked at SAE at the time the IXB was designed and he designed the inductors. I've asked him if it's OK to give you his email address.
Craig
Old 3rd December 2019, 07:41 PM   #19
audiomachines,
I sent you the email address of the man that designed the inductors in IXB.
Craig
SAE Preamplifier Equalizer Mark IXBHide this!Advertise here!
equalizer with a pre Mark Levinson No. 380s audiophile.1963 Solid State 1 22nd May 2016 01:22 PM
Marry tube preamplifier with 2-Band Wien bridge equalizer gooduser Tubes / Valves 13 11th October 2014 06:23 AM
Mark Audio Mark-Ten or Holly65 with the Gardient AXT-08 Ronald67 Full Range 4 11th January 2014 09:01 AM
Mark Bass Little Mark 800 Schematic iriegnome Solid State 0 25th January 2010 04:34 PM
PreAmplifier & Equalizer Ayne Solid State 0 4th May 2007 06:29 PM
Copyright ©1999-2019 diyAudio
