Power supply and quiescent current
Old 8th November 2019, 10:27 PM   #11
Rolox is offline Rolox
Originally Posted by Mark Tillotson View Post
You mean apart from to your bank balance? Seems an illogical approach given the lack of data on most of these products and the fantastic performance levels achievable with much cheaper parts. That money is probably better spent on improving room acoustics and loudspeakers.
That's another debate I don't wish to get into - I've been using IC opamps countless times I just want to experiment discretes for once, plus they were cheap.
Old 9th November 2019, 12:14 AM   #12
Mark Tillotson is offline Mark Tillotson
Ah, these chinese ones I guess - it would be good if you can document their performance relative to standard opamps - power consumption, noise (voltage and current and flicker), distortion at 2k and 600 ohms.
Old 13th November 2019, 12:07 PM   #13
I couldn't gather much.
The only available specs (at least on the sellers page, maybe it would be possible to contact the factory but, who is the factory? haha) are:
Ultra low distortion: 0.0008%
Low noise: 4nv√Hz
BJT-Input: 30pA
High speed: conversion rate -120V/us bandwidth -8MHz
High open loop gain: 120dB (600Ω)
Power supply range: 12V~18V (standard 18V)
and the fact that they are unity gain stable and protected against phase issues.
They do actually offer a quite extended range of discrete op-amps with gradually increased bandwidth and open loop gain, and proportionally increased price. I got the cheapest - risk is minimal and I thought it might be the easiest to use in a NE5532 circuit. They advertise this as being the ideal NE5532 replacement, wich probably means nothing anyways.
Power supply and quiescent currentHide this!Advertise here!
Quiescent current in F6 jazzzman Pass Labs 17 20th November 2016 03:00 AM
quiescent current different on both channels? crippledchicken Solid State 6 21st November 2004 03:55 AM
measuring quiescent current of power amp question crippledchicken Solid State 2 19th November 2004 11:57 PM
P3a No quiescent current! PetarLD Solid State 9 17th February 2004 02:20 AM
Quiescent Current JohnClark Solid State 13 16th November 2001 09:20 PM
Copyright ©1999-2019 diyAudio
