Best volume control
Best volume control
Old 23rd September 2019, 07:45 AM   #1
tribute is offline tribute  Australia
Default Best volume control
Hi, I am about to try to build a pre-amp & want to make sure I get the best vol cntrl available.
I had initially thought of the Alps Black Beauty, but that is apparently not available any more.
Definitely need something better than the Alps Blue pot, don't mind stepped resistor attenuators, but it must have more than 24 steps, otherwise the vol increase between steeps is to big.
Happy to go up to around $150 for a unit.
Cheers thanks for any input
Old 23rd September 2019, 08:37 AM   #2
Zung is offline Zung  Switzerland
The TKD's are good and available, just do a search. Also have a look over in the CTC thread where they were mentioned a few times.
Old 23rd September 2019, 10:34 AM   #3
diyiggy is offline diyiggy
Did you think about electronic pot like the Muse chip? Hard to beat and cost less.
Old 23rd September 2019, 05:30 PM   #4
Mark Tillotson is offline Mark Tillotson
Good mixer-desk slide-pot might be a worthy contender - not rotary, but should be some that are very well engineered and within budget (motorized too if you want).
Old 23rd September 2019, 05:49 PM   #5
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
http://www.ti.com/lit/ug/tidu034/tidu034.pdf
Old 23rd September 2019, 06:12 PM   #6
Originally Posted by scottjoplin View Post
20dB isn't much dynamic range for a volume control, but good for a gain preset.
And the mechanical pot doesn't look anything special (hard to tell). I'd suggest something with a reasonably logarithic response down to -40dB or lower is needed
Old 23rd September 2019, 07:02 PM   #7
Probably not the best example of a Baxandall volume control, but an alternative for the OP to think about
Old 23rd September 2019, 07:27 PM   #8
euro21 is offline euro21  Hungary
Best volume control
If continuous assertion is the main consideration, the conductive plastic potentiometers (like Noble, TKD) are the best ... but I regularly use transformers (S&B, Silk, Promitheus, Slagle) as volume control (TVC, AVC) -with low output impedance driver-.
The 1.5-2db step is enough small for me, and TVC/AVC "musicality" outperforms any pots.
Old 23rd September 2019, 08:22 PM   #9
grunf is offline grunf  Croatia
grunf's Avatar
My vote for Penny & Giles D22660 1120 / D, 10k log. I don't know what the new models are, but this one sounds great. I use it as the only component between the signal source and the amplifier.
File Type: jpg penny-giles-d22660-potenciometri-slika-62657467.jpg (58.1 KB, 1038 views)
Old 15th October 2019, 08:49 PM   #10
johnhenryharris is offline johnhenryharris  United States
Or, you can go with a digital stepped attenuator:
Preamp Control - Volume, input, mute, remote
Best volume controlHide this!Advertise here!
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 08:20 PM
Remote control Passive Volume Control with Display ua100k Swap Meet 2 31st May 2011 04:01 PM
Replacing broken volume control with digital volume control Gunawan W Solid State 19 15th December 2010 11:46 AM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 04:12 AM
remote control motorised control for volume pot/knob CharlesY Parts 0 25th July 2005 12:12 PM
Copyright ©1999-2019 diyAudio
