Need an opinion on layout of LME49713 preamp
Old 5th November 2019, 04:03 AM   #91
rayma is offline rayma  United States
Originally Posted by sonidos View Post
Ahh, got it, ok. Thanks. I'll read up on the pdf. Boy, next time I work with an op amp,
I'll pick a more pedestrian version!
Watch for the trick of mounting the smt cap on its side.
Old 5th November 2019, 07:27 PM   #92
sonidos is offline sonidos  United States
Libertador de la Música
sonidos's Avatar
I appreciate all the input and I'll enjoy going back through the thread when I layout alternate boards when I'm done with this one. Most likely I'll go with what Jan recommended so I can swap op amps, and I'll likely stay away some from such a wide bandwidth part in the future.
I'll read up on the pdf that rayma posted and downsize the cap size. I've also avoided low impedance electrolytics as it seems from my research into wide bandwidth op amps that a little resistance helps. I believe on other threads, others mention a low ESR part isn't always called for and this appears to be one.
Need an opinion on layout of LME49713 preampHide this!Advertise here!
An honest opinion over this dyn. mic. preamp Please octavian12 Analog Line Level 3 6th July 2015 07:56 PM
Using LME49713 for preamp, large DC offset Fusion916 Solid State 8 26th January 2015 06:48 AM
LME49713 preamp klewis Solid State 7 21st August 2009 03:55 PM
DC-DC buck regulator layout -> what's your opinion? Danko Power Supplies 14 31st December 2005 04:31 PM
Need opinion on PS for tube preamp. leadbelly Tubes / Valves 4 26th January 2005 02:33 AM
Copyright ©1999-2019 diyAudio
