Building the Akido All in One Noval Rectified for F4s
Old 10th August 2019, 02:40 PM   #1
Dneu2011 is offline Dneu2011
Default Building the Akido All in One Noval Rectified for F4s
I have been helping a friend who owns an audio shop build some DIY kits he acquired and included in the kits were an Akido all in one and enough parts to build a couple F4's. I have built one F4 and would like to get two exact copies built to run as monos as opportunities like this don't come every day.
The exact model I have is the All-in-one Noval with rectifier.
A few questions I have are:
- What tube orientation can I use to get the most out of two mono f4s or just one? The kit he has was originally purchased with 12au7s, but i understand they won't give the most gain.
-I will need some help getting the best power transformer. I currently have a 270cax that was supposed to be used with the 12au7s, but I am not sure if it would work with other tubes.
Most kits I have built give me exact instructions and the correct parts for the build, but I since I am changing from 12au7s to higher gain tubes I need a little help and direction.
Thanks!
Old 10th August 2019, 03:47 PM   #2
DF96 is offline DF96  England
Do you need gain? Most domestic audio systems do not.
Building the Akido All in One Noval Rectified for F4sHide this!Advertise here!
Octal Akido HP amp as pre amp supernut Tubes / Valves 5 7th May 2016 07:05 AM
What is your comment about akido linestage? Tubenstein Tubes / Valves 9 25th March 2013 09:53 PM
Akido help pls kendt Tubes / Valves 4 7th February 2013 08:02 PM
Adding Bal output to Akido Zero Cool Tubes / Valves 0 30th May 2011 02:30 PM
WTB Akido boards. Tony D. Swap Meet 0 6th December 2009 10:32 PM
Copyright ©1999-2019 diyAudio
