Preamp for Icepower and Minidsp
Old 9th August 2019, 11:26 PM   #1
calipilot227 is offline calipilot227  United States
Default Preamp for Icepower and Minidsp
Not sure if this is the right place, but I need to figure out a preamp solution that can go between a Minidsp and the Icepower 125asx2 in an active speaker build. Ideally, I'd like to have it fit into the speaker enclosure with the amp. The Icepower has 24v DC auxiliary power available. Any recommendations for a small preamp board with some gain?
Old 10th August 2019, 12:39 AM   #2
fab is offline fab  Canada
fab's Avatar
Hi
According to Datasheet:
Vin channel 1 , Vin channel 2
Maximum voltage range on pin
3.3 Vp
That means a preamp output not exceeding that voltage. What is the max output voltage of your Minidsp?
In any case my preamp can run with regulated voltage from the 24V unregulated auxiliary power supply. However, you need voltage regulators and you would need a minimum of 50ma current draw par channel.
USSPA Build thread
Gain can be set by ratio of resistors.
Fab
My stuff USSA, FSSA: https://fabaudio.online
Old 10th August 2019, 10:02 AM   #3
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
I use a PCA (SE Class A) as a preamp on my miniDSP. It gives just the right amount of gain (14dB) and a nice sound signature that makes a dry sounding Class D amp connected to the miniDSP sound like a nice 25W Class A amp.
Needs clean 18v to 19v power suppy. An LM7818 from 24v is perfect.
Preamp for Icepower and Minidsp-minidsp-pcapre-jpg
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 10th August 2019, 10:07 AM   #4
tcpip is offline tcpip  India
Really sorry to ask a stupid question, but what is a PCA? I've been seeing this TLA a lot lately, since I chanced upon Yarra and Melbourne.
Update: is it Pocket Class A? Is it a common noun or a proper noun?
Old 10th August 2019, 12:22 PM   #5
Got Foam?
xrk971's Avatar
Pocket Class A (my SE Class A headphone amplifier design - just an acronym but sort of became a name everyone calls it by).
Old 11th August 2019, 07:41 PM   #6
Originally Posted by fab View Post
Hi
Fab
Fab, the Minidsp can output 0.9v rms.
Old 11th August 2019, 08:51 PM   #7
fab's Avatar
Then you need a preamp gain of about 2.6 to get your max power amp input. I would recommend a gain of about 3 or 4 to cope for the lower level recordings.
Fab
Preamp for Icepower and MinidspHide this!Advertise here!
Minidsp preamp acoustic1 Analog Line Level 2 4th March 2019 11:26 PM
IcePower amp, and MiniDSP build ellisr63 Class D 10 20th June 2017 04:50 PM
FS: 2x MiniDSP 9.9/10 new PWR125WD 2x125W ICEpower plate amp - $175 each shipped bcodemz Swap Meet 1 1st December 2016 07:54 AM
MiniDSP preamp tcpip miniDSP 11 10th November 2016 08:03 PM
ICEpower preamp? Skorpio Class D 3 17th September 2009 05:50 PM
Copyright ©1999-2019 diyAudio
