relay as source selector - pop issues
Old 13th July 2019, 03:16 PM   #11
rottalpha is offline rottalpha  United States
rottalpha's Avatar
Originally Posted by mickeymoose View Post
+1 for post 4
Replace the 1N914, a small signal diode, with an 1N400x and do not use a resistor in series with the diode. E
will do
Thank you All for the quick replies. This thing drives me bananas
Old 13th July 2019, 03:22 PM   #12
sangram is offline sangram  India
I've used DC-coupled relay inputs for years now without issues, with no pops. Your source should have close to zero offset as far as possible.
The switch used is always MBB. You can't run away from that. The one time I had a deadline and only BBM available I put 1000uF caps on the relay coils to simulate a MBB action.
You will always need a pull-down resistor separately on each input, and do not make the mistake of switching grounds. That can be nasty.
If you like, you can use a small input series resistor and bounce the unused inputs to ground to reduce crosstalk from those inputs (note: tube output stages will NOT like this, and it increases the source resistance seen by the next stage - so it may be iffy with bipolar input stages). I don't usually do this anymore though, using brains and keeping unused sources powered off is a better bet.
Old 13th July 2019, 03:33 PM   #13
RickTH is online now RickTH
It's just a timer thing you can do with an RC + transitors or go with a CMOS timer . When you switch you let the output relay break the connection for let's say 200 ms but the switch over of the input selector relays after 30 ms or so . The relays switches in 5 to 10 ms as the datasheet shows so well witin the 200 ms.
I haven't got the Elektor circuit to show , but I tested it when I built my preamp . I didn't use it because 1) every time I switch the input the output relay would switch too , which makes 2 mechanical loud clicks , which I don't like . 2) The little click on the output is so small and short that it doesn't bother me . When switching 2 sources with a signal on , you don't even notice .
I'm not switching grounds .
If you have an output C and resistor , you can also go another way , that is used by some audio manufacturers and that is to mute (short) the output with a transistor . Not elegant but effective ... but here too you need timing through RC or timer IC.
This is from a Sony DAT player :
Old 13th July 2019, 03:34 PM   #14
rottalpha's Avatar
tried with both sources shorted to ground.
added pull-down resistors for both inputs.
do you mean an analog MBB? have a part number?
do you have a circuit you I could reference?
Many thanks!
Old 13th July 2019, 03:38 PM   #15
Fast Eddie D is offline Fast Eddie D  United States
Originally Posted by rottalpha View Post
I have tried ground leak resistors on both inputs. I will dig more into your suggestion.
Do you have more specifics or a reference circuit?
You need a ground leak resistor on both sides of the relay.
I use line level relays extensively. Here's what I use. D3002 TE Connectivity / P&B | Mouser
I use them to switch capacitors in active filters as well as for line level switching. Properly configured, the switching is 100% seamless.
Old 13th July 2019, 03:42 PM   #16
rottalpha's Avatar
will start with ground leak resistors and order some of the relays you suggested
thanks!
Old 13th July 2019, 04:31 PM   #17
thanks!
Ground leak resistors should be as large as possible. Example if input impedance is 47K you could use 470K leak down resistor.
If you make it too big, it will take a long time to pull down the capacitor. 470K is fine for say a 2.2 uF coupling cap.
For active filter circuits, you can go even bigger. It depends on the values of the capacitors and resistors in the circuit. Example if the largest resistor in the circuit is 100K then by the "rule of tens" you might choose a 1 meg pull down resistor. But even this value might significantly alter the transfer function of the circuit. However the capacitor values are typically smaller in such a circuit than coupling caps. Say you're switching between a 0.1 uF and a 0.068 uF capacitor. With these values a 2 to 5 meg pull down resistor will be fine, and will not change the circuit operation in any significant way.
Also it isn't a good idea to switch direct coupled audio circuits unless you have the offset very low and stable. A pull down resistor won't help you here.
Old 13th July 2019, 07:32 PM   #18
Mark Tillotson is offline Mark Tillotson
There are several ways a relay can inject switching noise into the signal. Here's my analysis:
Firstly if the signal is high impedance you may have capacitive coupling from the coil direct to the contacts or pcb. Solution is switch at a low impedance part of the circuit (opamp outputs), or slew-rate limit the voltage waveform going to the coil with a snubber circuit, and use groundplane.
Secondly the magnetic field from the relay coil may be cutting the signal path on the PCB, inducing voltages into them. Solution is reducing signal loop area on the PCB (slew-rate limiting is less likely to succeed as when the contacts snap together or apart the magnetic field changes rapidly even if the coil current is constant, as the magnetic circuit is mechanically changing?
In practice good layout, lowish impedance signals switched at line level shouldn't get too bad a click, but totally silent switching is unlikely to be possible with standard relays, they are not designed with magnetic and electrostatic shielding. Some experimentation would identify good and bad relays for these interference modes.
CMOS analog switch chips should be better, but you need to be careful to allow for the non-linearities of their on-resistance. Best to switch into a follower. Keep the digital logic traces away from the signals and over a digital groundplane. And usually you will be limited in headroom to the analog switch chip supply rails.
Old 13th July 2019, 07:39 PM   #19
stratus46 is offline stratus46  United States
Originally Posted by Chris Daly View Post
Hi Peter
Contact- less methods of switching are what you need to resolve the issue.
DC offsets will cause a pop regardless of the switching method.
G
Old 13th July 2019, 11:06 PM   #20
Chris Daly is offline Chris Daly  Australia
G
Agreed In a normal audio system there should not be DC present.
If the contact is some how making noise due to opening and closing, a option is Optocoupling using a NSL32SR3 per audio channel, which neatly removes the contact in switches, due to its Resistance Off figure of 25M ohms.
https://lunainc.com/wp-content/uploa.../NSL-32SR3.pdf on the downside is 60 ohms when ON, but is usually not problematic.
relay as source selector - pop issuesHide this!Advertise here!
Source selector issues vandalfsens Solid State 8 14th July 2018 12:43 PM
Resistor-Diode-Relay Logic Source Selector pmbrunelle Analog Line Level 20 20th June 2018 03:05 PM
Relay based source selector deafbykhorns Parts 8 23rd September 2017 08:02 PM
Relay based source selector. Help needed! MASantos Chip Amps 9 8th August 2007 11:28 PM
Relay switched source selector mike_steinert Chip Amps 2 3rd March 2007 07:22 AM
Copyright ©1999-2019 diyAudio
