active crossover
active crossover
Old 10th July 2019, 01:49 AM   #1
woody is offline woody
Default active crossover
I am building the Martin King open baffle speaker that calls for a 12db/oct Linkwitz-Riley high pass at 500hz for the fe103. I would like to bi amp . Could I use a simple rc filter set at 500hz on the amp input and then another cap on the amp output also as a 500hz first order filter? Something tells me it can't be this easy.
Old 10th July 2019, 02:11 AM   #2
Tromperie is offline Tromperie  Australia
What drives the woofer?
Source: LMS 7.9.2 on FreeNAS, PiCorePlayer * Storage: FreeNAS 11 * DIY PGA2310 * Amps: 8 x LM3886TF
Xover: 24dB @ 300 and 3kHz * Speakers: CNC cut 54 laminations * SB 10", SB 5", VIFA 1" * Remote: Squeeze Control
Old 10th July 2019, 02:16 AM   #3
ubergeeknz is offline ubergeeknz  New Zealand
You don't need both, just at the input.
Also you will want to filter the high frequencies from the woofer (so an equivalent low pass filter on the input to the woofer amplifier)
Old 10th July 2019, 02:55 AM   #4
I will be using another amp for the woofer.
ubergeehnz if I just use a cap at the input that will only be a 6db/oct crossover I need a 12/db xover. And my amp for the fe103 has to have an output cap so why not use it.
Old 10th July 2019, 01:34 PM   #5
Lingwendil is online now Lingwendil  United States
Lingwendil's Avatar
An input cap and output cap will give you 12dB if you already need an output cap anyway.
If you have enough gain you should be fine, or if you have an additional preamp with enough gain you can do it with simple cascaded RC filters between the preamp and amps.
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
Old 13th July 2019, 10:50 PM   #6
Mark Tillotson is offline Mark Tillotson
What driver the amp? Its impedance affects the filter on the input to the amp.
active crossoverHide this!Advertise here!
Do i need analog active Crossover or Digital Crossover for DIY home theatre speakers? dipankar862 Multi-Way 43 16th March 2017 05:55 AM
Help needed to decide: DIY Active Crossover or Passive Crossover? raelman Parts 5 1st October 2014 03:19 PM
Can you use a digital active crossover to design a passive analog crossover ? RickDangerous Digital Line Level 27 1st April 2013 05:59 AM
Active Crossover: Behringer x DBX active DriveRack 260 murillollirum Multi-Way 21 9th February 2013 07:12 AM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Copyright ©1999-2019 diyAudio
