USSPA Build thread
USSPA Build thread
USSPA Build thread Please consider donating to help us continue to serve you.
Old 9th November 2019, 02:45 AM   #101
AnthonyA is offline AnthonyA
Yes.. Ultra probably much better..less ringing..
If going for smooth musical Salas is good. Result will also vary some with different parts
If looking for more neatness, bass, control and attack. Try normal ic.. And the quieter the ic the more thin, clean the sound.
This is a couple free preamp.. It will depend alot on partnering equipment and supply.. Ie if your parts, dac or supply is bad it just reads it. I found some harshness in my dac sound because of this.. A quick modify it's good to go. Just use a good 60/40 type solder. Hi fi silver solder is a pain in the..
Old 9th November 2019, 02:46 AM   #102
Remember to snubber the transformer.. It's always better
Old 9th November 2019, 07:48 PM   #103
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
USSPA Build thread
If floating a PSU two L-Adapter can also be used like two batteries stacked with a midpoint. Just to let you know in case somebody has those high power positive only boards. Snubbers must be put externally across the secondary if desired.
Ultrabib board has snubber parts positions on each AC input area. Its three breakable units per board. Two plus and a minus section.
The better leaded solder wire in my view is Sn62 eutectic alloy. Among the best workable classic solders while still including 2% silver. Made by few established manufacturers. Loctite (Multicore) is one of those.
Old 14th November 2019, 04:49 PM   #104
I'm happy now with the sound after a little adjustments.
For those who like to hear it.. You don't have to come to my home. I had post it in you tube just to get an idea
Previous is also there under my videos. If you care to compare
Hope you like it
YouTube
Old 15th November 2019, 05:10 AM   #105
Harry3 is online now Harry3  Australia
How disappointing!
We all wanted to come to your place
Sounds good.
Old 15th November 2019, 10:45 AM   #106
meanie is offline meanie  Singapore
Make some final adjustments before they go into a proper chassis.
Marantz 7 clone - BA3FE - Yarra/Melbourne Preamp - USSPA - Korg Nutube - BabyHuey EL34s - 2ACAs - F6 - M2XSLB - 2Whammy -
USSA5SLB
Old 15th November 2019, 07:07 PM   #107
Danks Harry. Glad u like it.
Meanie.. Wow u got a great lab
Old 21st November 2019, 11:46 AM   #108
Heppy camper yet Ivan?
Old 21st November 2019, 10:09 PM   #109
They both sang previously inside Yarra.
Now i need more time to put them into proper chassis with their own powersupply.
USSA5SLB
Old 22nd November 2019, 03:41 AM   #110
Ok. Waiting for your reviews.
USSPA Build threadHide this!Advertise here!
Mod-286 build thread HarmonicTHD Chip Amps 201 16th January 2020 06:38 AM
F5-HA Build Thread cloud85 Pass Labs 57 29th November 2016 08:34 PM
SE - Build Thread soundengine355 Solid State 6 27th June 2009 01:19 AM
My SE KT-88 Build thread athos56 Tubes / Valves 13 21st December 2008 07:16 AM
The ESL Build Thread BillH Planars & Exotics 172 8th November 2006 10:01 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
