Preamp opamp instability
Old 6th June 2019, 09:31 PM   #21
egellings is offline egellings  United States
Hang a scope on it.
Old 6th June 2019, 09:34 PM   #22
rayma is online now rayma  United States
Originally Posted by egellings View Post
Hang a scope on it.
Sometimes that fixes an instability, instead of displaying it.
Old 6th June 2019, 10:57 PM   #23
Mark Tillotson is offline Mark Tillotson
Does the circuit have the appropriate decoupling for the new opamp?
Does the circuit avoid capacitively loading the new opamp beyond its stability limit?
Is the new opamp's input offset voltage and current going to cause output offsets larger than is desired?
These and other questions need asking and answering before any opamp substitution, they are not "rollable" in a naive sense.
Old 6th June 2019, 10:59 PM   #24
Hang the 'scope on the big amp's output, that won't have any effect on stability.
Also if you use x10 setting on a scope probe it provides a much smaller load and it less likely to affect the circuit being probed (ie never use the x1 setting without a good reason).
Old 7th June 2019, 03:11 PM   #25
justubes is offline justubes  Singapore
Thanks all, it seems possiblybultrasonics.
Cannthis cause or damage opamps downstream with ultrasonics being passed?
I will replace them back but concerned of any other issued caused downstream
Thanks again everyone for all the great advice and solutions!
Old 8th June 2019, 01:47 PM   #26
Opamps are not damaged by signals, its what they do!
Power amps and speakers can definitely be damaged by high amplitude ultrasonic signal.
Old 8th June 2019, 02:56 PM   #27
Thanks, so best never to swap opamps without putting the outputs to a scope for checking for stability and not havr any ultrasonics.
Something which may not affect the sonics but can wreck havoc with amps and speakers.
Old 8th June 2019, 03:00 PM   #28
diyralf is offline diyralf
diyralf's Avatar
Your preamp is not designed for Muses. Put back Op627 and it works.
Old 8th June 2019, 03:18 PM   #29
kevinkr's Avatar
I suspect you do not have an oscilloscope and have not checked to see whether the new op-amps are oscillating continuously or under some specific signal/time/temperature related condition and that is what is possibly destroying transistors in your power amplifiers. I would worry about your tweeters too.
The OP627 is an excellent op-amp and your pre-amp was designed and tested using this part, changing parts without understanding the consequences and testing for them is how you end up at this end of the street.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Preamp opamp instabilityHide this!Advertise here!
TL082 Preamp Instability SlunkBoy Analog Line Level 10 18th December 2012 06:22 AM
Opamp for Mic preamp -_nando-_ Analog Line Level 7 12th August 2011 11:55 AM
PS for opamp preamp Tolu Power Supplies 1 31st October 2008 09:53 PM
preamp with opamp...help cukkurullo Solid State 4 31st May 2006 07:25 PM
OpAmp in preamp Kevin McCready Solid State 4 18th September 2002 07:30 AM
Copyright ©1999-2019 diyAudio
