Why DC offset offset output.
Old 2nd June 2019, 11:52 AM   #21
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
The OP could do some measurements too.
a) measure the DC across the input pins; that's the input offset voltage;
b) measure the DC across the 47k R, which gives the input offset current.
Combined give the output offset voltage, as the input offset voltage X gain, plus the offset as a result of the input offset current. They may be with same polarity (which I expect for 200mV output offset) or opposite polarity and cancel partly.
Karl you could check the same on your breadboard.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 2nd June 2019, 06:24 PM   #22
Mooly's Avatar
OK, so same set up as before... can't guarantee they were all the same devices as before though.
From the start then. First readings with 910 ohm not connected, second set with. Vin in voltage between non inv and inv inputs. Meter neg on non inverting. VR is voltage across 47k, meter neg at inv input:
Code:
LF356
Vout = +1mV
Vin  = +1mV
VR   = 0.00V
Vout = +51.1mV
Vin  = +1mV
VR   = +50.3mV
4560
Vout = -1.1mV
Vin  = +0.8mV
VR   = -1.8mV
Vout = +39mV
Vin  = +0.8mV
VR   = +38.1mV
LM833
Vout = -13.2mV
Vin  = +0.3mV
VR   = -13.5mV
Vout = -0.2mV
Vin  = +0.3mV
VR   = -0.5mV
4558
Vout = -2.6mV
Vin  = +0.5mV
VR   = -3mV
Vout = +15.2mV
Vin  = +0.4mV
VR   = +14.9mV
1458
Vout = +1mV
Vin  = -0.8mV
VR   = +1.5mV
Vout = -25.7mV
Vin  = -0.7mV
VR   = -28.9mV
NE5532 (Philips)
Vout = +6.7mV
Vin  = -1.5mV
VR   = +8.1mV
Vout = -68.6mV
Vin  = -1.5mV
VR   = +68.2mV
Old 2nd June 2019, 06:31 PM   #23
jan.didden's Avatar
I think we can conclude that the offset is caused mainly from the amplified input offset voltage, except maybe for the LM833. That is an odd one. I must check its datasheet.
Back to the OP, he stated his 200mV output offset doesn't change with different opamps. Did he measure the DC at the opamp input pins?
Jan
Old 2nd June 2019, 07:57 PM   #24
Mooly's Avatar
The LM833 was an old original National Semiconductor one from the early 90's I guess.
We could do with knowing the set up for OP's original issue because something in his set up sounds very amiss. Pretty sure only output voltage was measured.
Old 3rd June 2019, 04:51 AM   #25
diy didi is offline diy didi  South Africa
Thank you all! Wow I didn’t expect so many replies and considerable effort from tou all.
I have taken your suggestions and used two 10uF caps on the inputs. Offset gone.
Thank you.
Old 3rd June 2019, 11:50 AM   #26
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Cool and glad you solved your problem
What I expected from the beginning, by the way
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Why DC offset offset output.Hide this!Advertise here!
How do you deal with output DC offset? Alan0354 Solid State 27 19th February 2015 10:01 AM
JVC VN-700 with 250 mV DC offset on output flyingtele Solid State 0 28th February 2012 02:55 PM
DH-220 Clone (SMART TA-242) can't adjust DC offset using offset bias pot? beady Solid State 6 17th March 2011 10:53 AM
Output DC offset. nigelwright7557 Solid State 3 20th April 2009 01:14 PM
Copyright ©1999-2019 diyAudio
