One Last Attempt at Discrete Opamp in DIP8 Footprint
Old 11th May 2019, 06:43 AM   #31
dreamth is offline dreamth  Romania
Pro Discrete Op Amp SS2590 - SparkoS Labs Inc.
Hypex NC500 Buffer Upgrade
https://sparkoslabs.com/wp-content/u.../03/SS2590.pdf
looking at the datasheet i can only be amused...it's only the power and the power supply that's better than any modern audio op-amp, nothing else...
Old 11th May 2019, 02:24 PM   #32
Mark Tillotson is offline Mark Tillotson
But surely the profit margin ($/unit) is massively higher? A very important performance criterion for many! And the self-congratulation coefficient is pretty high too
Obviously lacking is the current noise density, so there's no way to judge its noise figure in most small signal circuitry. Its apparently optimized for voltage noise with the paralleled input devices, which suggests it is not optimized for current noise (more important in reality for most uses, since typical circuitry is at 1k to 20k impedance, not 10 to 300 ohms!) The (uncorrelated?) input bias current cancellation circuitry doesn't bode well for this either.
The circuit looks good, the high gain, EF VAS and two-pole compensation should give great THD, but they never actually state the THD or graph it, which comes across as suspicious - it ought to perform well but why keep schtum in that case? The class AB output should give an interesting compromise in performance for heavy loads - which will cause an increase in output stage distortion without affecting the performance at low currents. Its basically a good BJT power amp with the feedback network and output stage chopped off AFAICT. The lack of THD measurements is immediately curious - perhaps something goes badly wrong with the output biasing?
Googling didn't seem to throw up anything about the current noise or measured THD or IM.
Old 11th May 2019, 03:56 PM   #33
A simple power buffer added to OPA454 (6 euros each for 1 pcs)and there's no competition in that voltage range...
http://www.ti.com/lit/ds/symlink/opa454.pdf
Old 11th May 2019, 04:16 PM   #34
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
The technical description contains plenty of nonsense.
"The way up and the way down are one in the same"
Old 11th May 2019, 05:49 PM   #35
Lingwendil is offline Lingwendil  United States
Lingwendil's Avatar
"Cascode structures inside of the device will begin to debias when the outupt swing approaches 3.5V
away from either supply rail. This is non destructive, and the output will not visibly clip, however
there will be a ~25dB reduction in open loop gain, resulting in higher THD."
This is terrible.
6SN7 Push-pull Flea Amplifier PCB files are now available!
Old 11th May 2019, 09:57 PM   #36
But you have +/-24V rails instead of +/-17, thats affordable, you're still 3dB up on standard opamps. As I said its a power amplifier with the output stage chopped off.
Old 11th May 2019, 10:12 PM   #37
Voltage noise density 35nV, 300nV at 10Hz. But its FET inputs so current noise not a problem. The compromises made for high voltage are costly - the dynamic range is much less than a standard part due to the voltage noise. Flicker noise knee seems to be somewhere between 1kHz and 10kHz.
The THD at x10 gain is about 25 times more than at unity gain, and rises precipitously above 1kHz to 0.035%
The GBW product is 3MHz, explaining the bad HF distortion at gain rather well.
So doesn't stack up at all against regular parts at +/-17V since all of the extra headroom is pissed away on noise, and the basic bandwidth is missing.
Old 11th May 2019, 10:23 PM   #38
Monte McGuire is offline Monte McGuire
It's not a single pole amplifier, so the effective feedback isn't as simple as determining the 0dB gain frequency (3MHz) and counting backward at 6dB per octave. For example, the amplifier open loop gain shown on the graph is about 85dB at 10kHz, not possible with a 3MHz single pole amplifier.
I guess this also means that there are circuits you can put it in that it will not be stable, but it'll probably work over some sort of gain range - have not explored this amp in detail.
Old 11th May 2019, 10:39 PM   #39
Mark...I still see no competition in that discrete op-amp...
Old 12th May 2019, 06:22 PM   #40
Lingwendil's Avatar
For the majority of applications where you're working with the "usual" rail voltages that's pretty poor headroom.
Overall there are better, cheaper choices that would offer better performance, even at higher rail voltages.
One Last Attempt at Discrete Opamp in DIP8 FootprintHide this!Advertise here!
DIP8 sized pcb for bootstrapped opamp 00940 Analog Line Level 6 24th August 2018 04:00 PM
LF03s Fully-Discrete DIP8 Opamp for MyRef Rev C or similar linuxguru Vendor's Bazaar 11 7th December 2015 11:10 AM
NZ / OZ GB: Nat Semi LME49710 opamp DIP8 len_scanlan Group Buys 23 12th November 2009 12:02 AM
Dual discrete opamp PCB in DIP8 tiroth Solid State 77 6th May 2008 11:51 PM
Copyright ©1999-2019 diyAudio
