One Last Attempt at Discrete Opamp in DIP8 Footprint
Old 5th May 2019, 06:36 AM   #11
EUVL is offline EUVL  Europe
Precisely what I do not want to do.
1) cross-over distortion, as in any commercial IC opamps
2) extra components required for biasing
3) thermal tracking difficulties of NPN to PNP
The only advantage is more driving capabilities.
For typical line level applications with 10k load, 8mA NJFET Source Follower is more than enough.
But it is only my personal design choice.
Others might have other choices.
Patrick
xen-audio.com
Old 5th May 2019, 11:07 AM   #12
basreflex is offline basreflex  Spain
the dominant pole in these circuits are the BJT PNP stages. Ft/beta.
ever considered a high Ft pnp pair like the HFA3135 .these need cascoding for voltage compliance. also good to reduce for early voltage distorsion.
Old 5th May 2019, 11:15 AM   #13
A few issues here :
1) Not easily available. No stock at Digikey & Mouser.
2) Hfe 5x lower than the ones used.
3) NF 3~4dB higher
And do you have a spice model for those ?
Patrick
xen-audio.com
Old 5th May 2019, 11:31 AM   #14
avtech23 is offline avtech23  Australia
Certifiably addicted to DIY.
avtech23's Avatar
I find it so interesting to read your design decisions as to what would work better and why. Often the 'why' doesn't get explained which makes it so much harder to learn.
Good luck with it and please keep feeding us lurkers
The ever growing project list.. :NAP140 Clone, NAD 3020i & 3225PE, JLH1969, TDA2050, Fender 5F2A Princeton, NE5532 Pre, SHPA, B1 Korg, T2. : VSQC Phunk Style, Retro 50W, Filmosound 601, LM4780. : Apex AX-14, TGM-10, TDA7265 (Last in line)...maybe
Old 5th May 2019, 11:38 AM   #15
you could start simming with a BFT92, just to see if you can move GBW up, to improve slew with less capacitance.
Old 5th May 2019, 11:45 AM   #16
gerhard is offline gerhard  Germany
gerhard's Avatar
Not exactly what you wanted, but RF PNP users cannot be choosers today.
* Siliconics / Renesas HFA3046/3096/3127/3128 Transistor Array SPICE Models
* SOI process Rev. 1.0 February 1994 Appnote MM3046.pdf 9 & 5.5 GHz ft
* ghf: in the next line they wrote PUHF also... must have been misprint
.model NUHFARRY NPN
+ (IS = 1.840E-16 XTI = 3.000E+00 EG = 1.110E+00 VAF = 7.200E+01
+ VAR = 4.500E+00 BF = 1.036E+02 ISE = 1.686E-19 NE = 1.400E+00
+ IKF = 5.400E-02 XTB = 0.000E+00 BR = 1.000E+01 ISC = 1.605E-14
+ NC = 1.800E+00 IKR = 5.400E-02 RC = 1.140E+01 CJC = 3.980E-13
+ MJC = 2.400E-01 VJC = 9.700E-01 FC = 5.000E-01 CJE = 2.400E-13
+ MJE = 5.100E-01 VJE = 8.690E-01 TR = 4.000E-09 TF = 10.51E-12
+ ITF = 3.500E-02 XTF = 2.300E+00 VTF = 3.500E+00 PTF = 0.000E+00
+ XCJC = 9.000E-01 CJS = 1.150E-13 VJS = 7.500E-01 MJS = 0.000E+00
+ RE = 1.848E+00 RB = 5.007E+01 RBM = 1.974E+00 KF = 0.000E+00
+ AF = 1.000E+00 )
.model PUHFARRY PNP
+ ( IS= 1.027E-16 XTI= 3.000E+00 EG= 1.110E+00 VAF= 3.000E+01
+ VAR= 4.500E+00 BF= 5.228E+01 ISE= 9.398E-20 NE= 1.400E+00
+ IKF= 5.412E-02 XTB= 0.000E+00 BR= 7.000E+00 ISC= 1.027E-14
+ NC= 1.800E+00 IKR= 5.412E-02 RC= 3.420E+01 CJC= 4.951E-13
+ MJC= 3.000E-01 VJC= 1.230E+00 FC= 5.000E-01 CJE= 2.927E-13
+ MJE= 5.700E-01 VJE= 8.800E-01 TR= 4.000E-09 TF= 20.05E-12
+ ITF= 2.001E-02 XTF= 1.534E+00 VTF= 1.800E+00 PTF= 0.000E+00
+ XCJC= 9.000E-01 CJS= 1.150E-13 VJS= 7.500E-01 MJS= 0.000E+00
+ RE= 1.848E+00 RB= 3.271E+01 RBM= 9.902E-01 KF= 0.000E+00
+ AF= 1.000E+00 )
"That's right!" shouted Vroomfondel, "we demand rigidly defined areas of doubt and uncertainty!" "We don't demand solid facts! What we demand is a total absence of solid facts. I demand that I may or may not be Vroomfondel!"
Old 5th May 2019, 01:07 PM   #17
At this moment, I am quite happy with the design as they are.
And I have bad experiences with HF devices.
I am not in a spec race, which I shall not win anyway.
So if anything, only the 4V/Ás slew rate (required for unity gain stability) is a touch low.
But that still gives me almost 1MHz at 1Vrms out at G=1.
At G=10, bandwidth is no longer slew rate limited.
It is still a healthy 300kHz.
I guess quite sufficient for most applications.
I could also reduce the amount of compensation, if I do not need to have unity gain stability.
But that would be customising.
All devices, especially the dual ones, are active parts and readily available.
And all are very low noise.
Patrick
xen-audio.com
Old 5th May 2019, 01:10 PM   #18
These are results of 18 months' work and many iterations.
So there is no straight forward explanation for everything.
Sometimes it is just a random choice by gut feeling.
Sometimes trial and error.
Of course you can always ask.
I'll see if I can give a rational answer.
And thanks for the interest,
Patrick
xen-audio.com
Old 5th May 2019, 01:16 PM   #19
dreamth is offline dreamth  Romania
Originally Posted by basreflex View Post
what about BJT classB complementary outputs?
vicious ))
Old 5th May 2019, 01:24 PM   #20
Patrick
There's no such thing for at least 30 years in audio op-amps on a chip.
It's only the chip technology that allows the class b output stages to have no crossover distortion and finally beat the class a in discrete technology on this aspect.If you're going to measure anything, i bet that you're going to do it with the aid of an ic with zero crossover distortion. Again, there's no benefit in having smd components on a pcb of a chip size...New smd chips have thermal pads that allow considerable heat dissipation .
One Last Attempt at Discrete Opamp in DIP8 FootprintHide this!Advertise here!
DIP8 sized pcb for bootstrapped opamp 00940 Analog Line Level 6 24th August 2018 03:00 PM
LF03s Fully-Discrete DIP8 Opamp for MyRef Rev C or similar linuxguru Vendor's Bazaar 11 7th December 2015 10:10 AM
NZ / OZ GB: Nat Semi LME49710 opamp DIP8 len_scanlan Group Buys 23 11th November 2009 11:02 PM
Dual discrete opamp PCB in DIP8 tiroth Solid State 77 6th May 2008 10:51 PM
Copyright ©1999-2019 diyAudio
