6J1 Tube Preamplifier u$s35.
Old 22nd April 2019, 08:07 AM   #11
t-minik is offline t-minik  France
ICG, did you find Tube-03 on Ali?
That one claims it boosts dc to 150v, but capacitors seem to be low v rated.
TIANCOOLKEI Tube Amplifiers Audio Board Amplificador DIY Kits Fever Bile Pre amplifier Hifi 6J1 tube headphones amplifier-in Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
Old 22nd April 2019, 01:57 PM   #12
ICG is offline ICG  Germany
ICG's Avatar
The page doesn't work for me, it says article not found. Maybe they don't want it to show in Germany?
As for the capacitors, there are several possibilities. The most logical would be to create the 150V with a cascade/voltage doubler or more in series. The capacitors are in series and therefore lower the capacity/current but increase the voltage rating and the effective voltage. The cascade needs a bunch of diodes and capacitors and AC voltage.
Another possible expaination would be they use film capacitors for the anode voltage, which have usually a much higher voltage rating and the electrolyte caps are. I can't tell though because I can't see the article.
They could also have a buck converter on the board and the low rating capacitors are just there to buffer the input or the voltages for the control ICs. because of high frequency of the converter a small film capacitor might be enough.
To make fake claims is ofcourse still a possibility though. That happens a lot on chinese sellers unfortunately. They usually don't just straight out lie but increase the numbers in the specification slightly.
I had a Déjà Moo - I've seen that BS before!
Old 22nd April 2019, 02:11 PM   #13
avtech23 is offline avtech23  Australia
Certifiably addicted to DIY.
avtech23's Avatar
Does this link work for you? Worked for me: TIANCOOLKEI Tube Amplifiers Audio Board Amplificador DIY Kits Fever Bile Pre amplifier Hifi 6J1 tube headphones amplifier-in Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
The ever growing project list.. :NAP140 Clone, NAD 3020i & 3225PE, JLH1969, TDA2050, Fender 5F2A Princeton, NE5532 Pre, SHPA, B1 Korg. : VSQC Phunk Style, Retro 50W, Filmosound 601. : Apex AX-14, TGM-10, TDA7265, LM4780 (Last in line)...maybe
Old 22nd April 2019, 02:18 PM   #14
ICG's Avatar
No, it says the page/article cannot be found. I don't expect the link to be wrong, it's much more likely they don't want the page to be displayed in some countries/areas.
Old 22nd April 2019, 04:34 PM   #15
Strange thing both links re working for me...
That Tiancoolki board is red with a vertical dc-dc converter and 100v rated Grey caps... Not very confident in...
In tube-03 Dc-dc is made with a uc3843a close to 75khz, exaxt schematics as that one except I don't get smd cap values :
https://danyk.cz/noteb_en.html
6J1 Tube Preamplifier u$s35.Hide this!Advertise here!
RCA tube preamplifier help bb2351490 Tubes / Valves 86 1st September 2015 10:55 AM
Tube preamplifier lpd Swap Meet 0 3rd November 2012 09:31 PM
My first tube preamplifier:) whee Tubes / Valves 4 29th September 2006 01:26 PM
Tube preamplifier gchrist Tubes / Valves 9 11th March 2004 03:06 PM
DIY Tube Microphone preamplifier gyraf Tubes / Valves 1 11th February 2003 01:12 PM
Copyright ©1999-2019 diyAudio
