Vendetta Research SCP-2A
Old 22nd April 2019, 04:44 PM   #11
kuly is offline kuly  Russian Federation
OHHH. Thank you very much and thank you !!!
Old 22nd April 2019, 05:32 PM   #12
EDDELARUE is offline EDDELARUE  Brazil
EDDELARUE's Avatar
File Type: gif Deliberate_1kHz_SquareWave_OverLoad.gif (22.0 KB, 396 views)
eD
Old 22nd April 2019, 05:57 PM   #13
EDDELARUE's Avatar
More band
eD
Old 22nd April 2019, 06:20 PM   #14
john curl is online now john curl  United States
john curl's Avatar
I meant pin 6, not pin 7. my mistake
"Condemnation without Examination is Prejudice"
Old 22nd April 2019, 07:15 PM   #15
OK!!!
The main problem is that there are no real transistors (2sk147------2sj75,,,,,.
I don’t want to bet on the Chinese! --- I’ll search for a long time at the Japanese auction - and then it’s possible that they already sit there and sell goods from China - the truth is not known
I recently for an amplifier luxman-bought in China (real !!!!) transistors-original))))
Listening is not possible nasty nasty sound!
the graphics are good))) - but the music is different
Old 23rd April 2019, 03:15 PM   #16
For John
Old 6th June 2019, 02:01 PM   #17
What can replace the transistor. J203 ?
which analog is available? j203
I put this - does not work mmbf j201
File Type: png ?????? ?????? 2019-06-06 ? 16.59.32.png (865.4 KB, 253 views)
File Type: png ?????? ?????? 2019-06-06 ? 17.02.23.png (683.0 KB, 234 views)
Old 6th June 2019, 02:47 PM   #18
ticknpop is offline ticknpop  Canada
I suspect you can use 2sk170/ 2sj74, they are being used as low noise current sources to set the output voltage of the jfet cap multipliers, but you have to select ones with the correct idss to set the output voltage when combined with the resistors 5k11 and 4k99 ( or the resistors are selected to match the jfets idss) anyway it ‘s the combination of the jfets idss and the resistor value that sets the output voltage
Old 6th June 2019, 04:03 PM   #19
Hooray! Thank ! I put sk170 - Earned!
modes are different i will pick up
5k11------!!???
4k99-------!!???
how to count them?
I will not reinvent the wheel !!!
I will buy J203 (204)
Old 28th June 2019, 05:56 PM   #20
The scheme turned on-the sound goes!
Applied other transistors-modes have changed and are not similar to the original. How do i fix skew 30mV-- 300mV. What can be leveled?
is 40mv in the left side ok?
The sound goes good plays well! help as you can adjust the scheme -modes?
please give good advice
File Type: jpg ?????? ?????? 2019-06-28 ? 20.59.01.jpg (169.2 KB, 124 views)
Vendetta Research SCP-2AHide this!Advertise here!
A real Vendetta? analog_sa Analogue Source 225 8th August 2019 01:09 PM
Vendetta Research TPC-1 f16voodoo1 PC Based 12 14th November 2018 01:02 AM
Vendetta research Miguel_Angel Everything Else 4 2nd June 2015 12:13 PM
Schematic For Vendetta Xover john dozier Analog Line Level 2 18th November 2011 07:36 PM
Vendetta crossover tomtt Solid State 0 30th June 2007 11:52 PM
Copyright ©1999-2019 diyAudio
