MCP42100 distortion
MCP42100 distortion
Old 10th April 2019, 01:11 PM   #1
ardiilves is offline ardiilves
Default MCP42100 distortion
Hello from Estonia to everyone! I have a sauna project in progress that got out of hand I have 3 sets of speakers to control (sauna, lounge and outside) and I wanted them to be individually controlled but one audio source. So I got 2 cheap aliexpress amplifiers (for sauna and outside, lounge has proper amplifier) and thought that this is it but nooo the idea evolved. I wanted to see sauna and hot tub temperatures from one place and also control speakers on/off and volume and hot tub filling/emptying. So I used arduino+nextion touch screen to control everything. Switched analog potentiometers on amplifiers with switch to digital pot and relay, two DS18B20 sensors to monitor sauna and hot tub temperature, two 12v solenoids (1 for filling and 1 for emptying) controlled with relays and water level sensor to shut off the water when tub is full. So I coded everything on arduino using pieces of code found on the internet and everything works like a charm except one thing. I used 2 MCP42100 dual digital potentiometers, one for each amplifier and I get huge distortion on sound when incoming audio levels are higher. I use bluetooth receiver and iPhone to transfer audio when I lower the volume on my phone everything is fine. Now I have to mention that this is my first project with arduino, amplifiers and digital potentiometers etc, piecing this together by experimenting. Can someone help me with this distortion issue?
MCP42100 distortionHide this!Advertise here!
Intermodulation-distortion and Doppler-distortion ?? aarvin2 Multi-Way 23 15th April 2018 02:33 PM
Separate driver distortion vs. whole speaker distortion mtoc Multi-Way 2 13th July 2016 05:49 PM
How Distortion Free are the Distortion Measurers? fas42 Equipment & Tools 108 10th May 2014 12:52 PM
Distortion Hojvaelde Tubes / Valves 2 18th August 2012 10:28 PM
Non Linear Distortion testing - Harmonic Distortion JMB Multi-Way 0 20th July 2004 02:54 PM
Copyright ©1999-2019 diyAudio
