LDR Pre MkII - LDR volume control and I/O switching
LDR Pre MkII - LDR volume control and I/O switching Please consider donating to help us continue to serve you.
Old 2nd September 2019, 03:43 PM   #251
fab is offline fab  Canada
fab's Avatar
Niss_man
Have you read this article about LDR thd profile ?
Tortuga Audio LDR3 Volume Control: Measurements & Review
Fab
My stuff USSA, FSSA: https://fabaudio.online
Old 27th September 2019, 10:05 AM   #252
zdr is offline zdr  Belgium
zdr's Avatar
I uploaded new firmware for graphic oled, corrected some issues with press and hold commands on remote.
Custom PCBs, BOM and LDR Firmware:
https://sites.google.com/view/dacgear/
Old 7th October 2019, 05:57 PM   #253
maal is offline maal  Poland
I found some time and installed the preamplifier in the chassis.
Old 9th October 2019, 03:30 AM   #254
ppap64 is offline ppap64  Canada
Hi. In the power supply BOM C3,4,5 are listed as 100nF caps, but the mouser link is a 220nF cap...which one is correct ?
Thank you.
Old 9th October 2019, 06:13 AM   #255
zdr's Avatar
Either will work fine.
Old 21st November 2019, 09:15 PM   #256
zdr's Avatar
I made another firmware which incorporates second encoder for direct input switching, and button used for on/off function for power amp, very useful for amps.
Old 21st November 2019, 09:21 PM   #257
zdr's Avatar
Allows you to build something like this
Old 30th November 2019, 05:21 PM   #258
zdr's Avatar
I did some cumulative THD measurements, with sine passing through this chain: USB DAC>LDR Pre (volume at 36)>RMI-FC100 > PC internal sound card. At 1KHz, THD+N is around 0.05%. Not sure what I am doing wrong.
Old 1st December 2019, 08:39 AM   #259
zdr's Avatar
Test with 300mV Vrms input signal. Signal path: USB DAC>LDR Pre MkII>RMI-FC100>Scarlet 2i2.
Old 1st December 2019, 08:42 AM   #260
zdr's Avatar
Same setup, volume at 40.
LDR Pre MkII - LDR volume control and I/O switchingHide this!Advertise here!
S&B TX 102 MKII Volume Control Transformes wattsman Swap Meet 2 19th November 2018 08:30 PM
Bluetooth switching for stepped volume control? Technical Petting Parts 0 31st January 2018 09:59 PM
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 08:20 PM
Replacing broken volume control with digital volume control Gunawan W Solid State 19 15th December 2010 11:46 AM
About volume control and input switching Janne Nivala Solid State 7 15th August 2001 06:50 AM
Copyright ©1999-2019 diyAudio
