LDR Pre MkII - LDR volume control and I/O switching
Old 13th July 2019, 01:09 PM   #221
sabre66 is offline sabre66  Canada
Originally Posted by zdr View Post
Scl and sda are pulled to vcc with 2k2 resistors so they should be around 5v. Make sure you modified oled without any errors. It seems that scl and sda are messing with i2c bus preventing arduino from booting.
That what I was thinking. The modifications of the old OLED seem ok so I'm just going to wait for the new oled. Until then I'm going to wine country.
Old 15th July 2019, 07:52 AM   #222
zdr is offline zdr  Belgium
zdr's Avatar
You can try putting a cap of around 1000uF on D+ line, in case you have garbage injected from OLED.
Custom PCBs, BOM and LDR Firmware:
https://sites.google.com/view/dacgear/
Old 15th July 2019, 07:53 AM   #223
zdr's Avatar
Another display that works with this project, requires no additional components to be soldered and cheapest I could find:
White 2.42" 2.42 inch LCD Screen 12864 OLED Display Module IIC I2C SPI Serial for C51 STM32 SSD1309-in Integrated Circuits from Electronic Components & Supplies on Aliexpress.com | Alibaba Group
Old 17th July 2019, 05:53 PM   #224
zdr's Avatar
Sorry folks, there has been an error in how to do a hardware mod on your displays. You MUST NOT pull DC to VCC, otherwise you will set I2C address to 0x3D, and firmware looks for 0x3C. So the correct instructions are below:
R4 - remove
R3, R5, R7 - 0R (short with blob of solder)
RES - connect to VCC with 10K resistor (pullup)
RES - connect to GND with 10uF cap (keeps RES low during display power up)
Old 18th July 2019, 05:10 AM   #225
R4 - remove
Thank You for the update !!!!!!!!
Powered up and calibrated but im going to get some clips for the ldrs I just could not get a proper hold of them.
Paul
Old 18th July 2019, 05:12 AM   #226
zdr's Avatar
Paul
There are big holes next to each ldr used to stick your probes for measurements
Old 18th July 2019, 05:14 AM   #227
Awesome!!!! thanks again
Old 18th July 2019, 05:25 AM   #228
Do The parameters need to be changed ? They are all set to min of 40 or do I need to set their actual measured values are lowest of 40.5 and highest 52 my D+ is 5.06
Old 18th July 2019, 05:32 AM   #229
zdr's Avatar
Yes, you need to set min values. You can measure them while in set menu and put values directly in.
Old 20th July 2019, 04:30 PM   #230
So after 2 days of testing ( and working great) I woke up this morning and I noticed the unit was frozen up so I rebooted now the screen sometimes lights up with garbage or with one or two lines showing and no ir response. I have my new oled coming maybe thats the issue Im not sure.
LDR Pre MkII - LDR volume control and I/O switchingHide this!Advertise here!
S&B TX 102 MKII Volume Control Transformes wattsman Swap Meet 2 19th November 2018 07:30 PM
Bluetooth switching for stepped volume control? Technical Petting Parts 0 31st January 2018 08:59 PM
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
Replacing broken volume control with digital volume control Gunawan W Solid State 19 15th December 2010 10:46 AM
About volume control and input switching Janne Nivala Solid State 7 15th August 2001 05:50 AM
Copyright ©1999-2019 diyAudio
