LDR Pre MkII - LDR volume control and I/O switching
Old 10th June 2019, 02:58 AM   #131
sabre66 is online now sabre66  Canada
Hi I am really interested in this in this setup but is there a schematic? I cannot seem to find one. Also I presume R+ D+ and A+ are the three 5VDC that you mention in the first post.
Old 10th June 2019, 03:04 AM   #132
rbalu72 is offline rbalu72  India
Unfortunately No schematic available....
Read post 1 and subsequent thread. ZDR developed this version direct on a PCB. This requires a nano board with specific chip and lot of customisations at hw/sw applied to it. Dont think you can take up this as a diy project from ground up without the modded nano/firmware and pcb with circuit.
Send him a PM for any available PCBs/Kits...
Old 10th June 2019, 03:12 AM   #133
Thanks for the reply I do plan on ordering the kit ASAP just filling in parts needed with digikey.
Old 10th June 2019, 03:51 PM   #134
maal is offline maal  Poland
I added control over the wifi network to the preamp using the ESP-01 module (ESP8266).
The software running on ESP emulates the voltages sent by the TSOP34438 receiving signals from the the Apple Remote.
ESP generates voltages on pin GPIO2 (connected to the data pin of TSOP34438).
The ESP module connects to the WIFI network and listens to commands on port 80.
Example of sending "PLAY" button over the IP network (here from linux):
Code:
$ echo "p" | nc -n <ESP_IP_ADDRESS> 80 -q 0
Connections:
3.3V PSU ______ ESP-01
3.3V <------------> VCC
3.3V <------------> CH_EN
GND <------------> GND
ESP-01 __________ TSOP34438
GPIO2 <------------> DATA
GND <--------------> GND
Source code (for the Arduino IDE) in the attachment.
Old 11th June 2019, 07:02 AM   #135
zdr is offline zdr  Belgium
zdr's Avatar
Code:
Connections:
Nice!
Custom PCBs, BOM and LDR Firmware:
https://sites.google.com/view/dacgear/
Old 13th June 2019, 08:41 PM   #136
streetpreacher is offline streetpreacher
Already assembled, now lets test and correct any mistake I made.
Old 14th June 2019, 09:19 AM   #137
Need some help.
After everything assembled Iīm having error 20.
No voltage on any of the 3 relays near LDR, but if I give them 5v directly they operate.
If I try to set bias, measure the ldr and try to calibrate it stop on step 19.
Sorry but, please can you tell me how to debug this to try to solve the problem.
Old 14th June 2019, 12:05 PM   #138
zdr's Avatar
First of all, if you are getting any error at boot, this has to be cleared first as nothing else will work if errors are present. I have included a way to go around this error simply to allow to browse the setup menu and do measurements in different modes for troubleshooting purposes.
Three relays on the side are particularly critical as they are calibration relays. If you have no power on them, then you probably donít have power on any of the relays as they are on the same power line. DC issues are easy to trace, just follow the voltage from R+ dc input.
Old 14th June 2019, 02:03 PM   #139
The ULN2003 was erratic, new one and everything is running perfectly.
Thanks ZDR for all
My brother is amazed for this design, probably one more client for the board
Old 17th June 2019, 05:42 PM   #140
ernesternest is offline ernesternest  Europe
ernesternest's Avatar
Default arduino
Hi Neb, I finished my build yesterday and tried to power it up today. I have the 1602 display and it showed just squares plus some strange letters or numbers. After a while letters stopped and there were just white squares.
I switched off the thing and reswitched it. Nothing at all.
Tried to flash the arduino, since I thought there might be something wrong. Followed your proposal but was not successful. Program found Arduino but couldn't connect to it. The system tried to connect for 10 times, then stopped. Strange. So I think I killed it with anything. Any idea?
I ordered a few of them for a new try.
Ernst
LDR Pre MkII - LDR volume control and I/O switchingHide this!Advertise here!
S&B TX 102 MKII Volume Control Transformes wattsman Swap Meet 2 19th November 2018 07:30 PM
Bluetooth switching for stepped volume control? Technical Petting Parts 0 31st January 2018 08:59 PM
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
Replacing broken volume control with digital volume control Gunawan W Solid State 19 15th December 2010 10:46 AM
About volume control and input switching Janne Nivala Solid State 7 15th August 2001 05:50 AM
Copyright ©1999-2019 diyAudio
