Improvements on the common emitter amplifier
Old 19th March 2019, 07:46 AM   #21
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Are you referring to Elvee's circuit above? Note that this is two times the same circuit, one without the diode, one with the diode. This will enable measuring the distortion on the two collectors to compare the effect of the diode.
When building it you would only build the right side part.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 19th March 2019, 08:46 AM   #22
oon_the_kid is offline oon_the_kid  Malaysia
oon_the_kid's Avatar
Thanks for the heads up. Don't worry. I know what is happening. It is a Comparison circuitry. I used to use Spice 20 years ago in its more primitive state. I need to spend some time catching up on it. I didn't know that it is now possible to simulate THD on it...
Oon
Old 19th March 2019, 09:43 AM   #23
jan.didden's Avatar
Old 19th March 2019, 10:51 AM   #24
BesPav is offline BesPav  Russian Federation
Originally Posted by oon_the_kid View Post
Probably about 500 ohms output impedance and ability to swing 4Vp-p and a gain of 4X.
Ok.
Really there are only two basical ways:
1. Drop stage amplification via so-named local negative feedback. I.E. relatively increase emitter resistance.
2. Drop stage amplification via so-named global negative feedback
I’ld prefer to load CE stage to a current source, inverting connection and relatively high bias.
Old 19th March 2019, 04:13 PM   #25
Elvee is offline Elvee  Belgium
Elvee's Avatar
Thanks, I don't have big targets for this, I think anything below 0.1% is adequate.
I will try this one out and see how it goes.
Oon
Note that both the textbook example I gave and the Kulish circuit do work, but they have major issues from a practical point of view: they are sensitive to loading. The diodes circuit will have the compensation upset if the load impedance significantly modifies the collector load.
The compensation with the Kulish will not be altered very much by loading, but the output impedance will need to be higher, because the ratio of resistors becomes unfavorable as soon as the gain is larger than 1.
This means that in practice, both circuits would require a follower, to eliminate the influence of the load on characteristics. With this in mind, it is better to act directly at the source of the distortion, the emitter circuit, rather than the collector circuit. Here is an example using a diode to compensate for the non-linearity.
With this sim, the THD improvement is only ~10dB, but that's simply because the compensation is not tweaked to the optimum. With a suitable compensating junction and resistor values, the compensation could be similar to the two other ones.
However, there is an even simpler solution: use a CFP composite instead of simple transistor: the improvement is >20dB, and importantly, it does not require matching or tweaking to attain that performance level (circuit 3). That amounts to negative feedback of course, but the topology remains simple....
. .Circlophone your life !!!! . . ♫♪ My little cheap Circlophoneİ ♫♪
Electrify your daily life!!! ....⚡⚡ ELEKTRIA ⚡⚡
Old 20th March 2019, 07:34 PM   #26
PRR is offline PRR  United States
PRR's Avatar
...I used to use Spice 20 years ago in its more primitive state. ...I didn't know that it is now possible to simulate THD on it...
I use a version from 1999 (20 years old). The old-old SPICE .DISTO was notoriously bad and mine does not seem to offer it. It has .FOUR which computes THD, and with good agreement to pencil and breadboard if used properly. The Probe program has a FFT function which will find non-harmonic byproducts.
Here's 1KHz and 2.4KHz mixed 1:1 in FFT. We get products at 1k*, 1.4k, 2k, 2.4k*, 3k, 3.4k, 3.8k, 4.4k, 4.8k, 5.8k, 7.2k, 8.2k, 8.6k, 9.6k, 14.8k..... Roughly as expected, though 4.0k is not showing.
Old 20th March 2019, 11:51 PM   #27
Hi Elvee,
Do you mind just posting the circuit alone. It doesn't seem to appear properly in your screen capture.
Thanks.
Oon
Old 21st March 2019, 12:57 PM   #28
dreamth is offline dreamth  Romania
Thanks for the advice.
Just try it!.The circuit and its gain formula are very simple.The gain formula is on the first page of one of the links in the photo.You have google too.Given the fact that you have an internal feedback you also have very high input impedance and should also have a bit lower output impedance compared with the naked common emitter. The audio electronics literature is full of simple and very good circuits that are ignored just because some other's big talk...More complex circuits doesn't necessarily mean better circuits too.
Old 21st March 2019, 08:20 PM   #29
Elvee's Avatar
Here it is again:
Old 21st March 2019, 09:36 PM   #30
AKSA is offline AKSA  Australia
In that case, PRR's CFP at #4 is the best option of all.
HD
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Improvements on the common emitter amplifierHide this!Advertise here!
Simple shunt feedback common emitter power amplifier Ranchu32 Solid State 8 16th January 2017 11:29 AM
Half Watt Common Emitter amplifier sanbadgujar Solid State 28 6th November 2015 04:54 AM
Is a Fuzz Face a common-emitter or common-collector circuit? ninopelo29 Instruments and Amps 6 9th December 2011 01:38 AM
CE (common emitter) Amplifier help SCKentrol Solid State 3 8th May 2011 07:52 AM
Calculation of input impedance (Common emitter amplifier) jazko Solid State 22 22nd January 2011 10:35 AM
Copyright ©1999-2019 diyAudio
