Running TV analog out to a simple class D amp
Old 5th February 2019, 12:27 AM   #1
disorder is offline disorder  United States
Default Running TV analog out to a simple class D amp
Sorry if this isn't the right spot. I didn't see TV's listed in any of these source forums. I have an old Vizio TV with basic analog audio out via the red/white RCA cables. I was kind of bummed to find out that the volume control on the TV effects the level of this output signal. I know, I know... it's probably so you can still use your TV remove to set volume. However I would have liked basic line level audio. This leaves me wondering how should I balance the volume on the TV with the volume control on the amp (Tripath TA2021 Class D). The amp feeds a Bose Acoustimass 3 Series III setup. Should I max the amp and set the TV accordingly? Or start with both at 50% and adjust TV from there?
Old 12th February 2019, 05:38 AM   #2
Extreme_Boky is offline Extreme_Boky
It might be possible to un-tie the TV volume control from the RCA outputs, to let RCA's output what they should... .a constant 150mV or so. Look in the TV settings / audio settings.
if you don't get lucky in TV settings => then, it really depends on how clean (from pops/clicks during a TV turn ON <-> turn OFF) that RCA output is... I'd bypass the volume control in Tripath and wire RCA outs straight to the Tripath's first stage of amplification. Dangerous, but it would give the best sound.
Old 12th February 2019, 12:43 PM   #3
indianajo is offline indianajo  United States
indianajo's Avatar
If you disconnect the TV speaker, you can adjust both volumes for the least hiss. That is what I do.
The sound out of this new Samsung flat screen is vile. No RCA out of this, only patented optical out compatible only with Samsung's $190 sound bar. So I have a tuner from Newark, $39, which has RCA jacks out for audio. Then I feed the TV video with the Yellow RCA jack. With RCA splitters I can feed both and turn the TV sound up if I want, but the TV delays sound about 1/5 second compared to the signal from the tuner.
I don't guess this trick would work with a cable box, but I don't intend to pay $80 a month for commercials. PBS that I watch is broadcast over the air .
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 12th February 2019, 01:29 PM   #4
leadfinger is offline leadfinger  United States
Hello indianjo,
I just installed a Samsung 7100 series tv for my sister. I used the tv optical digital output into a SMSL Q5 amplifier from Parts Express. In tv sound setup you have to change the digital out from bitsream to pcm in two places. Once you do this it works perfect. The tv digital out is fixed, the tv volume does not control it.
Old 12th February 2019, 01:32 PM   #5
Guerilla is offline Guerilla  Denmark
Since its old it might have audio out via scart connection. Then you would only need a scart to phono adapter
Running TV analog out to a simple class D ampHide this!Advertise here!
Running 4 ohm speakers with my Simple SE Coreyk78 Tubelab 4 19th July 2009 02:23 AM
class a running hot freo Solid State 16 28th April 2007 02:59 AM
Running op-amp in class-A Skorpio Solid State 8 16th April 2004 09:05 AM
Running the KSA-100 in Class A/AB? Jan Dupont Solid State 9 15th April 2003 06:52 AM
Copyright ©1999-2019 diyAudio
