Balanced Output Circuit Variations versus Noise
Old 21st January 2019, 10:22 PM   #11
rsdio is offline rsdio  United States
Originally Posted by billshurv View Post
Thanks for that link. Quoting from page 8, "Unless there are pressing reasons to build an electronically floated output I shouldn’t bother."
There are certainly many cases where the reason is pressing, but not when you can control what device is connected to the output.
Old 21st January 2019, 10:30 PM   #12
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
Originally Posted by leadbelly View Post
Beware that the cross coupled outputs are only conditionally stable. There have been bad experiences in the PA world of the cross coupled specialty chips being unstable driving long cables, albeit some chips are better than others.
Hence why I said that for long cables the THAT1646 has a lot going for it. For domestic use I don't see a problem. But worth pointing out that pros have their own problems, sometimes big ones .
Bruno has a nice way with words. Of course in your case the pressing need might be that you cannot drive your ADC to 0dBFS without a differential drive.
Old 22nd January 2019, 05:56 AM   #13
PRR is offline PRR  United States
PRR's Avatar
......would be thwarted if ......
You can build all four of your plans, twice for stereo, for about ten bucks. 2% resistors are cheap by the dozen.
Do that, using '5532 and ~~2K, AND direct unbalanced connection to balanced input. Use normal program sources. See if any sound "thwarted".
Old 22nd January 2019, 06:08 AM   #14
Good point. I still don't own an AP, but I could certainly build all of these and borrow one.
Balanced Output Circuit Variations versus NoiseHide this!Advertise here!
adding balanced output capability to my unbalanced 4-ch gain stage circuit CharlieLaub Analog Line Level 17 14th April 2017 11:56 PM
Meridian 502 balanced output circuit EssB Analog Line Level 0 15th February 2014 01:39 PM
Help with circuit for preamp with eq and balanced output powered by phantom power jabeavers Analog Line Level 25 4th February 2013 01:35 PM
Balanced versus Unbalanced Output skibum Digital Line Level 3 24th January 2011 06:32 PM
Two variations of same circuit 2Bak Chip Amps 7 31st January 2004 11:30 PM
Copyright ©1999-2019 diyAudio
