Krell KBX Crossover Info Needed
Old 17th February 2019, 05:25 PM   #11
Groove T is offline Groove T  Switzerland
Groove T's Avatar
I had this problem to on one of my KBX, problem a was broken Transistor due broken cap, causing a broken resistor.
So you have to check out the specific stage, all is balanced, thus you can get reference values of parts, so you can desolder some parts and do measurings of Res. and Caps and you have a way to find the bug.
Yes , lots of work and patience.
Notice, often the trimpots for setting DC make problems to, this means, make picture of the pot position, move it with a screwdriver, take original position and check out if corrosion caused the problem.
Good luck.
Frank
Old 18th February 2019, 11:30 AM   #12
willcycle is offline willcycle  United States
I figured out the function of all pots and how to adjust them. DC offset is under 1 mV on all outputs.
I modified the network board to work with my speakers so between that and normal drift of components over 30 years there was a lot of DC offset (over 100 mV) initially which varied with the attenuator position. This was due to offset from the network board being attenuated with pot position.
Krell KBX Crossover Info NeededHide this!Advertise here!
Krell KSA info 02GF74 Solid State 8 15th September 2017 03:30 PM
Krell KMA-160 schematic and biasing info needed cmjohnson Solid State 1 11th March 2014 06:12 AM
KAS2 Krell info Ahutchy Solid State 1 1st November 2010 11:23 PM
KRELL KSA50 power supply - kind request of info. beppe61 Solid State 32 5th November 2005 03:44 PM
Copyright ©1999-2019 diyAudio
