Increase input impedance with LL1540?
Old 8th January 2019, 06:22 PM   #11
jev is offline jev  Netherlands
Great tip!
Indeed I just now send a mail to Connex about the input cap. I think looking at the print there is a bipolar of 10uF there. Not so nice if this is indeed the case
Old 8th January 2019, 10:02 PM   #12
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by jev View Post
...impedance (3k6). ... cap needs to be 30uF to reach 20 hz which is my goal for the subwoofer....
30uFd into 3.6k is 1.5Hz @ -3dB, 3Hz @ -1dB, 6Hz @ -0.5dB.
_I_ would try any good 5uFd cap before I would put a transformer in there. A C and an L together form a resonance. If you do not do your math, it may be a slight slump or a huge peak. A 47uFd bipolar electrolytic or a 6uFd motor-run capacitor should do fine for a lot less cash than a transformer.
Old 9th January 2019, 09:51 AM   #13
DF96 is offline DF96  England
Almost any cap is going to do a better job of passing on audio unmolested than almost any transformer. I don't understand your reluctance to simply use the right cap value, or simply add a buffer.
Old 11th January 2019, 06:49 PM   #14
I plan to have the following order:
> Pre amp (ultrapath transformer coupled)
> Tube based filter with 1uF at the end
> Stepped attenuator 50K
> Opamp buffer with some gain (no cap at the end), powered by the extra 2*18V on the power amp
> Power amp (have no answer from Connext but I guess the have implemented an input cap)
So no reluctance but would prefer to use hi Q caps only and prefer low value caps
Old 11th January 2019, 06:55 PM   #15
I used this calculator:
Coupling Capacitor Calculator by V-Cap
They say:
3db Frequency (Hz): 1.47
Optimal low frequency response (Hz): 14.74
For 20hz I would need indeed "only" 22uF:
-3db Frequency (Hz): 2.01
Optimal low frequency response (Hz): 20.10
Old 12th January 2019, 10:32 AM   #16
Preferring low value caps and hearing bass are two conflicting requirements. You choose.
Faradaphobia is a horrible disease, because it forces its sufferers into taking all sort of peculiar actions to avoid the source of their pain. It is curable, but it takes a while and the occasional relapse is likely.
Old 12th January 2019, 07:25 PM   #17
Yes yes point taken :-)
Increase input impedance with LL1540?Hide this!Advertise here!
Increase input impedance nzlowie Analog Line Level 3 21st March 2018 07:57 AM
Increase Power Amplifier input impedance Zaharescu Mihai PA Systems 34 20th December 2017 09:57 PM
How To Increase Driver Nominal Impedance? Jay Multi-Way 11 26th April 2011 06:33 PM
increase (mather) impedance? tweed Instruments and Amps 7 3rd June 2006 04:10 AM
How to increase the input impedance of a pre-amp ? DonOE Solid State 6 9th May 2005 04:45 AM
Copyright ©1999-2019 diyAudio
