Grid hum despite line transformers
Old 8th January 2019, 10:28 AM   #1
JanErik is offline JanErik  Finland
Default Grid hum despite line transformers
I have an active crossover for bi-amping and have now built an input selector/volume control using ESP32, relays, opamp buffer and PGA2310.
Originally I was going to feed it from the filters grid transformer. It employs a dual half-wave rectifier to double supply voltages and SMPS modules down to +12V and +5V (in series). -12V linear. This, though, resulted in grid hum.
With a separate AC wallwart, it is silent.
Now once again I tried to feed it from the crossovers transformer and connected a line isolator/transformer on the lineout, but it still hums! How is this possible? The signal comes out clear otherwise. I can not see how there would be a ground loop anymore.
On another forum I got the suggestion to put 10nF commutation capacitors over the rectifier diodes, could this help?
Old 8th January 2019, 11:07 AM   #2
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
With half wave rectification you need smoothing capacitors twice as big.
PCBCAD51 download or CDROM 2019 version out now http://www.murtonpikesystems.co.uk
Old 8th January 2019, 11:27 AM   #3
DF96 is offline DF96  England
A ground loop is not the only possible source of hum. Why not show us the PSU you built?
Old 9th January 2019, 07:29 AM   #4
Yes of course, and it is silent with a separate 18VAC wall wart.
Old 9th January 2019, 07:55 AM   #5
I cant draw at the moment but it is quite basic - has two half wave rectifiers; 1N4001 and respectable size electrolytic plus 100nF ceramic.
Negative side uses 7912 regulator and that feeds opamp and PGA2310.
Positive side uses one chinese SMPS/buck converter to 12V (opamp and PGA2310) and from 12V another buck converter down to 5V for digital logic.
Electrolytics and ceramics on all rails after regulators. 100nF on all chips' supply pins.
Old 9th January 2019, 10:48 AM   #6
If you cannot show us what you built then we cannot do remote diagnosis. In many cases hum from a PSU is caused by poor grounding - most people seem to naturally get this wrong even though there is plenty of information around on how to get it right.
Grid hum despite line transformersHide this!Advertise here!
UTC A-11 line to grid transformer Otto Vaughan Tubes / Valves 1 29th October 2017 02:39 PM
diyAB Amp The "Honey Badger" on line grid board Zymorg Solid State 34 27th May 2017 01:33 PM
Grounded Grid TRANSCENDENT line stage widi Tubes / Valves 12 12th September 2012 08:41 PM
Why do you need a grid to ground resistor on a line stage? phrarod Tubes / Valves 7 7th May 2010 03:35 AM
Grid Input Transformers rdf Tubes / Valves 7 5th August 2005 08:24 PM
Copyright ©1999-2019 diyAudio
