Hi
I've purchased a 12AX7 12AU7 Tube Preamplifier HiFi Pre-Amp Shigeru Wada Japan Circuit kit from eBay Douk Audio 12AX7 12AU7 Tube Preamplifier HiFi Preamp Shigeru Wada Japan Circuit 8112417629285 | eBay
Has anyone else built this kit. I'm new at building amps and I've been slowly going through the circuit diagram. However I was wondering if anyone has some pictures of the inside of amp, showing the wiring and connections, which I can use as a guide with the circuit diagram I have.
Thanks in advance for your help
Phill
Phill
The picture shows how not to wire a heater, for one of them. The valve at top centre has the heater wires encircling the valveholder, to get to pins 5 and 9?. All the books say this is the wrong way to do it as it maximise magnetic hum field at the valve.
Of course, it may use DC heaters, but then why bother to twist at all?
How to manage the ground bus
Hi all,
Thanks for your help. Looking at the images of the circuit diagram and also the physical image of the circuit. It looks like it's using the chassis as the ground bus. However I can't see how that connects to the neutral. Also it looks like from the photo, they haven't earthed the chassis. Any thoughts?
cheers
Phill
Hi all,
cheers
Phill
