Switching Phono preamps
Presumably these are stereo preamplifiers, so you need four rather than two poles if you simultaneously want to switch the inputs and the outputs. Besides, you need gold-plated rather than silver-plated contacts to reliably switch very-low-level signals. Silver contacts will work fine for a few months and then start to produce cracking sounds, which you can usually get rid of by switching back and forth a few times.
