Analog filter group delay: maximum allowable in HIFI
Assuming no all-pass filters are present, the frequency response is much more important. If in doubt use Bessel filters.
In fact Bessel filter has a flat group delay, but it is a disaster for frequency response flattness. I need to move more on Butterworth, with good response but bad group delay. So need a compromise between the two: then the question how much (in us) group delay is still ok?
Account Closed
Joined 2001
Have a look at Blauert and Laws from 1978.
There are already numerous threads on this topic here at DIYaudio.com and elsewhere. It's an interesting topic, but "audibility" requires a subjective evaluation....and if doing that any conclusions get really interesting. :)
Dave.
Dave.
Mmmm interesting.
It appears that a group delay of less than 400us is not audibile for the most and, thus, it is not harmful.
So we are speaking about hundreds of microseconds, and not a few.
Then I don't understand why it should be so important maintaining flat the group delay for a post DAC analogue filter... A Butterworth filter do not have milliseconds of group delay...
Also, it seems that loudspeakers have group delays many orders higher!
There are two things to consider besides audibility or inaudibility:
1. Amplitude roll-off can be compensated for in a linear-phase FIR oversampling filter. Compensating for phase errors would require a FIR filter with asymmetric impulse response, which is more expensive because it needs twice as many multiplications per second.
2. Due to a series of coincidences, the first Philips CD players already used a linear-phase FIR oversampling filter. Philips then also chose a nearly linear-phase analogue reconstruction filter, compensated for its roll-off with the FIR oversampling filter and used the phase linearity of the CD player as a selling point. They were quite successful with that, so competitors soon also went for nearly linear phase.
By the way, there is a fairly new thread about an allpass filter audibility test on this forum: Audibility of allpass phase distortion (test)
