0.9V to 2.0V four-way line level booster amp for MiniDSP 2x4
I bought the MiniDSP 2x4 years ago and am yet to put them into service. The problem is the 0.9V output does not suit my setup. I have searched the forums and found nothing suitable.
Can anyone suggest a specific fully working circuit I can use to design and fabricate a PCB, please?
There are a lot of gain stages you could use. You can get a simple 5532 op amp gain stage on Ebay, or build your own. You could build the Nelson Pass BA-3 gain stage (or two if you need all four channels). Nelson also published some single transistor gain stages like the JFET BOZ that you could try.
I have the Minidsp 2x4, and as I only need the output from two channels at present, I have it sandwiched between the two gain stages of a Rod Elliott Project 88 preamp. If I needed four outputs, a pair of Project 88 preamps would be a good bet.
I'm sure there are many other options, but these are a few.
