Dynaco PAS 3x Quad Cap and ticking sound
Old 13th September 2018, 02:12 PM   #1
jimmeq is offline jimmeq  United States
Default Dynaco PAS 3x Quad Cap and ticking sound
I'm a noobie to rebuilding and have started with a Dynaco PAS 3X. It was working but not sounding good so I began changing one part at a time. So far I've replaced the rectifier and the caps under it, the transformer and recently the Quad Cap. I got it from DynakitParts.com- a 30-20-20-20. I also replaced the 47K and two 10K resistors at 1/2 W that are soldered to the cap.
When I turn on the amp, after about 10 seconds I hear a slight *tick* sound and the power indicator light bulb flickers.
Should I have used 1W resistors?
Old 13th September 2018, 02:55 PM   #2
J247W is offline J247W  United Kingdom
Sounds like you have not soldered something properly, check the soldered joints under a "magnilamp" if you have one ? try to wiggle the components to see if anything moves, but with power off or course.
Check the components you have replaced are the right impedance as well.
J247W
! It is better to sit on a recliner chair than one to sit on a wooden chair !
Old 13th September 2018, 04:34 PM   #3
dtaylo3 is offline dtaylo3  United States
I would recommend going to Triode Electronics Home Page and World HQ and getting the Sheldon Stokes board/kit for upgrading power filtering, etc. It removes the selenium rectifier, quad cap, puts in a necessary fuse, improves the capacitor filtering, etc.
Old 14th September 2018, 03:02 PM   #4
Thanks for the help! Very much appreciated. I make one change at a time just so when something like this happens it's easier for me to try and figure it out. And then there are often those times I can't... I do have a magnifying glass and a bright light....
I'm only replacing the old parts trying to stay with as much of the original design as I can.
Dynaco PAS 3x Quad Cap and ticking soundHide this!Advertise here!
Ground isolation loop problem ? Motorboat ticking sound rajkumar88 Chip Amps 13 26th April 2017 08:46 PM
wierd ticking/clicking sound from switching power supply CharlieLaub Power Supplies 24 28th June 2016 02:15 AM
15" RCF bass driver - cause of ticking sound? capslock PA Systems 26 17th May 2013 08:23 PM
Ticking sound from bass driver Lexluthor Multi-Way 1 26th September 2006 09:37 AM
ticking sound in new woofers - cause, remedy? capslock Multi-Way 7 30th January 2003 02:57 PM
