Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Thread Tools |
#151 |
Thank you for ordering! Give me a day to check what I can include with it as a controller.
As for a limited menu idea - thank you. I will think about a practical way to make it work. |
#152 |
Here is a one minute video showing the MUSES board and the controller in action.
The display is a 4-digit alphanumeric LED display from Spark X, based on the HT16K33 controller. The volume level is displayed in percent, 0 to 100. The remote is an old (white) Apple remote; the newer aluminium one also works. Pairing and unpairing of the remote is supported. Last edited by alexcp; 20th January 2021 at 05:07 AM. |
#153 |
Blue display in keeping with First Watt / Pass Labs - I like it.
Does the job. Looks and sounds good to me. |
#154 | |
As a follow on, any idea of the product longevity of the SPX-16426?
There's a comment on the linked page Qwiic Alphanumeric Display, Blue, SPX-16426 reads: Quote:
Even so, it looks like a good option. Sparkfun's documentation helps those slow on the uptake like me. EDIT: Based on what I'm seeing here, my guess is that this piece of kit will hang around for a while. Last edited by astromo; 22nd January 2021 at 12:55 AM. Reason: More info |
#155 |
Mouser in the US has only one in stock. Although the hardware design files are available from SparkFun, and the board can easily be replicated, the specific LED display they used is nowhere to be found. I guess I will need to switch to a display with longer term availability. Shouldn’t be too difficult.
#156 |
The controller board is 1.1x1.1in and carries six 0.1in pitch headers:
All connectors except LED carry power, so any one of them can be used to power the board, and the remaining ones - to provide power to other devices. Normally, the power is provided by the volume controller board, which carries a 5-volt regulator. In turn, the controller provides power to the IR receiver and display. Other arrangements may be possible. The controller board needs between 2.7 to 5.5 volts. The display from SparkX works with both 3.3 and 5 volts. The attached pictures show the size of the board and connector placement. |
#157 |
Nice work.
What are the units of measure for the dimensions shown? |
#158 |
Thank you! The dimensions are in 1/1000 in.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Balanced Audio Volume Controller with PGA2310 | yangsmm | Chip Amps | 5 | 16th March 2009 09:37 AM |
Balanced Audio Volume Controller with PGA2310 | yangsmm | Chip Amps | 7 | 24th November 2008 01:54 AM |
Balanced Zen v5 + balanced Zen line stage | Adrie | Pass Labs | 0 | 30th May 2004 06:27 PM |
Zen Balanced Line Stage Balanced vs Unbalanced | macka | Pass Labs | 28 | 11th December 2002 07:18 AM |
New To Site? | Need Help? |
