have you checked the input side as well?
T turk 182 Member Joined 2012 2018-02-12 2:15 pm #21 2018-02-12 2:15 pm #21 have you checked the input side as well? ••• More options Share R Roksan Member Joined 2010 2018-02-12 2:33 pm #22 2018-02-12 2:33 pm #22 Depending on what van damme interconnect cable you are using-you could have a thin resistive (black Sleeve) surrounding the signal core. You need to make sure the signal core is not touching this sleeve at your termination points. Hope this helps Last edited: 2018-02-12 2:40 pm ••• More options Share Prev 1 2 First Prev 2 of 2 Go to page Go Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button.
