AKSA's Lender Preamp with 40Vpp Output
Old 21st November 2018, 01:12 AM   #891
BRN is offline BRN  United States
Does the pot need to be 10k or can a 25k or 50k used?
Old 21st November 2018, 04:41 AM   #892
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Any of those pots will work.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 21st November 2018, 01:34 PM   #893
marconi118 is offline marconi118  Germany
Originally Posted by marconi118 View Post
can I use the transistors of the v2.0 for the HV in the regular version?
will it reduce the preformance (thd)?
Old 21st November 2018, 07:09 PM   #894
Got Foam?
xrk971's Avatar
The V2.0 SMT transistors will have similar THD, although I have seen that the SMT layout may have lower THD than the TH version. Use of metal thin film transistors for the outputs and feedback makes a difference though. Do not use metal oxide resistors on the feedback.
Old 21st November 2018, 07:10 PM   #895
Got Foam?
xrk971's Avatar
The Melbourne M2X DB
The diyAudio First Watt M2x
Old 22nd November 2018, 08:18 AM   #896
Do you mean resistors?
I saw that in the normal version, in the HV version, in the M2 hybrid version and in the M2X doughter board, the transistors are different.
AS I will go with the hybrid M2 version without edcor and with only 3 transistors, best to use are?
BC857
BC556
2N5401
KSA992
Old 23rd November 2018, 12:35 AM   #897
Got Foam?
xrk971's Avatar
Sorry, meant resistors. I think my phone autocorrected that.
They all work about the same. 857 same as 557 butnin SOT23.
KSA992 is high Hfe but pins different than BC.
Old 23rd November 2018, 08:06 AM   #898
I have in stock BC559C low noise but max 30V Vce and Vcb
can I use them? should match them for Hfe
Old 23rd November 2018, 03:32 PM   #899
Got Foam?
xrk971's Avatar
They will work fine, just match Hfe.
Old 23rd November 2018, 03:35 PM   #900
Got Foam?
xrk971's Avatar
Melbourne DB for M2X progress is coming along:
AKSA Lender Pass Hybrid M2 (ALPH-M2) Amp-mel-smd-pba-bot-v2-png
AKSA Lender Pass Hybrid M2 (ALPH-M2) Amp-mel-smd-pba-top-v2-png
AKSA's Lender Preamp with 40Vpp OutputHide this!Advertise here!
FS: AKSA GK-1 (EL) Preamp kit kv2 Swap Meet 1 14th April 2017 11:04 AM
Alternative output transistors for the Baby AKSA 55 cs Solid State 10 13th September 2013 10:06 AM
preamp for aksa 55 Professor smith AKSA 98 12th February 2012 12:11 AM
Borbely-Lender True Symmetry steph_tsf Solid State 33 23rd August 2011 12:52 PM
Aksa preamp? rick57 Solid State 11 19th May 2006 09:26 PM
Copyright ©1999-2019 diyAudio
