AKSA's Lender Preamp with 40Vpp Output
Old 21st August 2018, 02:06 AM   #791
GASCo is offline GASCo  United States
GASCo's Avatar
Is that @120v?
Old 21st August 2018, 02:22 AM   #792
ggetzoff is offline ggetzoff  United States
ggetzoff's Avatar
Originally Posted by Vunce View Post
My review will not be as eloquently written like Drproís was, but Iíll throw in a few of my thoughts.
Right from the start this preamp has been extremely quiet, no noises of any kind are added when using this pre. I feed it 24v-44v depending on the daughter board/amplifier combo being used and always a black/silent background.
This leads me right to one of my favorite features about this preamp, the ability to swap out the DBís for different situations required. Currently, Iím mainly flipping between my Alpha20 and Big MoFo amplifiers. They represent a huge difference in preamp requirements. Voila!! Install the ďcustomizedĒ DBís for either amplifier and you have one preamp thatís a perfect match to both amplifiers
How it sounds is very subjective because everyone uses different associated gear, unique room setups and styles of listening. So, Iím not going to go overboard here, but, two aspects continue to amaze me: a huge soundstage and an incredible amount of articulate low frequency detail. Iíll be passing through my living room and have stop in my tracks because I heard something different in a song Iíve heard 100 times before!
I feel the AKSA Lender Pre is going to stay in my main system for a long time.
Vunce,
That's great, thanks for doing that! Yes, of course there are lots of factors: source, speakers, amps, room, cables, ect., then you add a computer and it gets even more complicated. Anyway, I appreciate the the review.
Greg
Airline Pilot-If it's not Boeing I'm not going.
Aleph J, DCB1, VHEX + USSA-5, BA-3 Pre, DCG3, USSPA, Transcendent Sound Masterpiece
Old 21st August 2018, 03:51 AM   #793
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Originally Posted by GASCo View Post
Is that @120v?
mA bias current at whatever the Vcc is set at (24v to 48v).
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 21st August 2018, 05:12 AM   #794
JPS64 is offline JPS64  Germany
I don‘t want to miss it in my setup!
I‘m still waiting for transistors to finish KORG B1 Clone.
I‘m finishing ACA, MoFo, M2 and F6; don‘t forget ALPHA.
I‘m working on a SIT preamplifier using Russian transistors.
FAOW in the pipeline.
SissySIT in the pipeline.
I‘ll report!
PS: no PC, simply Shanling M2 perhaps later DSC2?!
JP
Old 21st August 2018, 05:18 AM   #795
GASCo's Avatar
Ok. I misunderstood his question then...
I was curious regarding total consumption since I read that smps thatís too oversized might be a bad thing...
Old 21st August 2018, 05:37 AM   #796
Skylar88 is offline Skylar88  South Africa
As a Preamp bias is about 25mA to 35mA per channel. As HPA itís 100mA per channel.
Thanks X.
Yes, I meant DC, as I was trying to establish whether the boost converter that Twocents is using is able to supply enough juice. Turns out it is plenty beefy at 2A max rating - which I tested and verified yesterday.
Old 21st August 2018, 12:50 PM   #797
Got Foam?
xrk971's Avatar
Twocents:
I had one daughterboard (TH) that I could not get working. Spent 5hrs debugging to no avail. I simply had to abandon it and make a new one in less than an hour. The new one worked fine upon first startup. Sometimes the problems are elusive indeed. I can send you a new pair of TH boards in the paper mail as a letter if you want - no charge. Should get there quickly.
Old 21st August 2018, 03:53 PM   #798
twocents is offline twocents  South Africa
twocents's Avatar
Twocents:
Well thank you very much X, you are always willing to walk the extra mile! I might take you up on that. Still cannot trace the problem, but I have not given up yet. The problem is duplicated as I built the daughter boards in parallel. I also have two other options - wait for Skylar to populate his daughter boards and test them in my setup, and/or get components and populate my SMT daughter boards. I will get there ...
Old 22nd August 2018, 06:29 AM   #799
The BOM calls for C5 to be a mica cap. (Mouser 598-CD15ED330JO3F)
How would a ceramic cap fare there?
This one: CERAMIC DISC CAPACITOR, 33pF, 500V
Old 22nd August 2018, 11:39 AM   #800
I'm trying to troubleshoot Twocents' build, by checking and measuring the components (prior to populating my own boards). We have exactly the same components, because we bought together. The 33pF ceramic cap is the only item that I'm unsure of, since it deviates from the BOM by not being a mica cap.
Here is a close-up of one of his daughterboards, showing the ceramic cap.
AKSA's Lender Preamp with 40Vpp OutputHide this!Advertise here!
FS: AKSA GK-1 (EL) Preamp kit kv2 Swap Meet 1 14th April 2017 11:04 AM
Alternative output transistors for the Baby AKSA 55 cs Solid State 10 13th September 2013 10:06 AM
preamp for aksa 55 Professor smith AKSA 98 12th February 2012 12:11 AM
Borbely-Lender True Symmetry steph_tsf Solid State 33 23rd August 2011 12:52 PM
Aksa preamp? rick57 Solid State 11 19th May 2006 09:26 PM
Copyright ©1999-2019 diyAudio
