AKSA's Lender Preamp with 40Vpp Output
Old 9th August 2018, 03:55 PM   #771
JPS64 is offline JPS64  Germany
@twocents
Could you post fotos from equipped top PCB?
I had same problem and had do mistake with two populated resistors.
JP
Old 9th August 2018, 07:43 PM   #772
twocents is offline twocents  South Africa
twocents's Avatar
Originally Posted by JPS64 View Post
@twocents
JP
Awesome - thank you very much JP for also making mistakes - I now found the problem with mine! I tried to take some photos but cannot get clear photos with my cell phone camera and artificial light. I then checked the orientation of the resistors against X's stuffing guide, and whala - there it is - R3 and R4A are incorrectly orientated. But to fix this will require some delicate soldering surgery. Damn, second mistake on this build.
Old 9th August 2018, 07:58 PM   #773
I did the same mistake! But good friend is expert solderer so problem solved quickly and now listing never ends.
JP
Old 10th August 2018, 12:04 AM   #774
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Contrary to popular belief, desoldering is not delicate but actually sloppy and messy... add lots of extra solder to the pads you want to remove to enhance the heat capacity to get it to soften to liquidus on both legs. When hot enough, pull out the offending part. Use solder sucker or copper braid with flux to clean up excess. Trick is not to pull on part until it is really liquid or a pad will come off too.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 10th August 2018, 09:24 AM   #775
twocents's Avatar
Thank you X for the de-soldering tips. It's waiting time again for me since I don't have those resistor values in my parts bin. I my case the resistors were not the offending parts - it was the offending builder who did not consult the documentation properly!
... and now listing never ends.
JP
Wow, this is promising and worth the wait.
Old 10th August 2018, 11:49 AM   #776
bassmad is offline bassmad
Hi everyone,
I am about to buy the PCBs kit to build this preamp. Will the PCB still contain errors (I have read earlier threads and saw some comments about a resistor and a diode I think)
or these were rectified in later revision PCBS (if there were any)?
Also, can someone tell me if this preamp is suitable to feed a valve amplifier? If so, should I isolate the preamp from the amp circuitry if I want to enclose this preamp IN the actual amp case? Aluminium case any good? Thanks a lot.
Old 10th August 2018, 01:41 PM   #777
Got Foam?
xrk971's Avatar
Default Errata - Please Read
The PCBs themselves are fine, there was a typo on the schematic which had the V141 diode for the cap multiplier portion of the main board spec'd as a zener but it should just be a standard 1N400x or even a 1N4148 can work - it is a protection diode to protect the gate on the MOSFET.
These were noted in the main GB thread. Please consult Post 1 of this thread for updates to any errors.
As far as I know these are the only 3 errors or typos. A PCB error would actually mean that a trace was wired badly or missing.
1. Error on main PCB schematic: R141 Should be 10k not 220R.
2. Error on main PCB schematic: diode V141 should be standard 1N400X not breakdown or zener.
3. Revised BOM for MB (8-pin connector was incorrect), file here:
http://www.diyaudio.com/forums/attac...04_01_2018-zip
4. Error on SMT Daughterboard schematic: R102/103 were swapped, schematic updated now.
Here is the TH board stuffing guide - follow it exactly for pin placement:
Old 13th August 2018, 07:44 PM   #778
twocents's Avatar
I finally got my Lender working! After some sloppy solder surgery the implants were successful resistors R3 and R4A replaced, this time on the back of the boards. The rebellious twin daughters are doing what they are supposed to do now. The mother is no longer shorting and causing smoke in the house and the father provides clean power. My Lender family is happy and singing . Almost filed for divorce a month ago.
The only mod on my build is R11 = 2k2. With this mod I feel the gain is still a bit low for my 88dB speakers. Only a quick listening test was done using a TDA7297 amp and Tannoy monitors. Maybe I must try something like 1k8 for R11? But this operation might be even more daunting as R11 is in the middle of the board. Anyway, I will test the Lender first with the ACA which I built it for.
Many of the motherboard caps were mounted underneath the board. This was to make space for larger heatsinks on the daughter boards.
How does it sound? I only did a few quick songs using the TDA. Compared to the B1 the most notable differences are an increased soundstage and an enormous amount of bass! Really looking forward to connect the Lender to the ACA.
Old 14th August 2018, 05:25 AM   #779
Got Foam?
xrk971's Avatar
Great work, Twocents! Glad you finally got it working.
Old 18th August 2018, 02:23 PM   #780
twocents's Avatar
Nope - still something seriously wrong with my Lender. Need help (again) please. I found it simple and easy to solder another 2k2 resistor on the back of the pcb to the existing 2k2 R11 resistor, which brings the R11 value to 1k1 - pretty close to the standard 1k0 for full gain. However, the Lender signal is still very very soft. My B1 plays twice as loud, which means the Lender does not seem to be working at all. I measure bias values of 31.9mA and 31.7mA. This just does not look right to me.
So, all components are according to the schematic. I have gone over all the components checked their values and orientation. I have checked all the solder joints. I am really not sure what to do next?
AKSA's Lender Preamp with 40Vpp OutputHide this!Advertise here!
FS: AKSA GK-1 (EL) Preamp kit kv2 Swap Meet 1 14th April 2017 11:04 AM
Alternative output transistors for the Baby AKSA 55 cs Solid State 10 13th September 2013 10:06 AM
preamp for aksa 55 Professor smith AKSA 98 12th February 2012 12:11 AM
Borbely-Lender True Symmetry steph_tsf Solid State 33 23rd August 2011 12:52 PM
Aksa preamp? rick57 Solid State 11 19th May 2006 09:26 PM
Copyright ©1999-2019 diyAudio
