AKSA's Lender Preamp with 40Vpp Output
Old 17th November 2017, 04:09 PM   #121
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
OSCOns are nice for feedback shunt cap or for output coupling cap where low ESR gives better bass authority and minor leakage is not an issue. They are also nice for space constrained applications where dense volume is needed. I use them as output caps on my pocket class A amp because it lets me fit 2000uF in a tiny space with two units.
I agree that they are not needed for the 100uF 50v voltage reference filter caps here. Almost any through hole 100uF 50v cap here will work well and save quite a bit of money ($0.15 vs $1.75 for example). Through holes can be mounted on opposite side of SMT side to allow more flexible arrangements as I have done.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 17th November 2017, 04:27 PM   #122
JPS64 is offline JPS64  Germany
@xrk971
Why R10 carbon? or non inductive? Carbon as SMD resistor is very difficult to order!
MELF or MINIMELF enabling possibility to route signals under themself (starting standard size 1206) and IMHO they are a good choice for audio (from 0102(MMU) to 0207(MMB); SMD holder only for 0204(MMA)); also available from all distributors. Footprints are IPC compliant.
Remember, the metal core PCB doesnt allow vias.
@sottomano
IŽll check datasheets. Unfortunately, ELNA SILMIC SMD RVF (up to 10”) or RVO/RVM types not yet available as small quantities order. Will check PANASONIC, RUBYCON and others.
JP
Old 17th November 2017, 04:42 PM   #123
Got Foam?
xrk971's Avatar
You missed the revelation a page back. This was killer to find - almost had to swap out every part on board to duplicate the veroboard before I found it.
Here is FFT with metal film SMT:
Here is carbon on R10 feedback resistor:
This confirms anecdotal reports that metal thin film resistors, when used in audio path, "sound harsh". It is extra sensitive in the feedback position. Matched LTP transistors hardly made any difference, and the difference it made was to reduce H2 even farther relative to H3.
You can take an axial carbon resistor and bend the legs to mount on 0812 SMT pad easy enough. Luckily, it is just this one resistor that needs to be carbon.
Old 17th November 2017, 04:48 PM   #124
Got Foam?
xrk971's Avatar
AKSA's Lender Preamp with 40Vpp Output-layout-top-png
Can you please show silk layer to see component labels and outlines? I only see 5 actives?
Old 17th November 2017, 05:08 PM   #125
Got Foam?
xrk971's Avatar
There is one other trick this circuit can do if you make R15=3.3R and R14=2.2R and drop Vcc to 24v. You get a pretty nice headphone amplifier! Here it is driving 4vpp into 250ohm load:
This is for 72mA bias current and about 900mW dissipation in each of the output devices and CCS MOSFET (still within spec).
Also, change output cap to bigger value if using lower impedance headphones. I put in 2200uF in sim but probably 470uF is enough for 250 ohm phones.
Old 17th November 2017, 05:30 PM   #126
Sk8Ter is offline Sk8Ter  United States
Very Impressive X.....keep up the great work!
Old 17th November 2017, 06:16 PM   #127
carbon 1/4W replaced.
100” --> PANASONIC FC (leakage 0.01CV), others stay OSCON.
All other parts (input/output caps, volume potentiometer, cap-multiplier, CRCRC) on mainboard (in progress).
JP
Old 17th November 2017, 06:39 PM   #128
Vrystaat is offline Vrystaat  South Africa
XRK, do you think you might be able to replicate this with carbon resistors on some of your other amps ?
Jan
Old 17th November 2017, 07:37 PM   #129
Default Not to Steel X fire here
I have been playing with different manufactured feedback resistors in my amplifier,they can make huge differences in sound for sure
I just did install some carbon films and you can clearly hear the third harmonic is lessened, this really can fool you into thinking you have less distortion for sure
I wonder how long for resistors to break in
Old 17th November 2017, 08:14 PM   #130
Ultima Thule is offline Ultima Thule  Europe
Ultima Thule's Avatar
Post Resistor choice in the FB path
X that is no doubt a good observation and well worth to keep in mind, may we know exactly what brand, power rating and tempco the mentioned resistors were of, thanks.
AKSA's Lender Preamp with 40Vpp OutputHide this!Advertise here!
FS: AKSA GK-1 (EL) Preamp kit kv2 Swap Meet 1 14th April 2017 11:04 AM
Alternative output transistors for the Baby AKSA 55 cs Solid State 10 13th September 2013 10:06 AM
preamp for aksa 55 Professor smith AKSA 98 12th February 2012 12:11 AM
Borbely-Lender True Symmetry steph_tsf Solid State 33 23rd August 2011 12:52 PM
Aksa preamp? rick57 Solid State 11 19th May 2006 09:26 PM
Copyright ©1999-2019 diyAudio
