AKSA's Lender Preamp with 40Vpp Output
Old 16th January 2019, 11:13 AM   #1001
Skylar88 is offline Skylar88  South Africa
I think once the main board and DB's are tested and working fine, it may be an option to solder the DB's to the main board. I've never felt very happy with the wobbly DB's. The cheapy header connectors were not designed to hold a board very tight and rigid without any other support. I've also considered adding support to the top edges of the DB's.
Old 16th January 2019, 11:46 AM   #1002
maf_au is offline maf_au  Australia
Originally Posted by twocents View Post
Maf_au – I agree with X – beautiful work!
I would also advise to use socket connectors on the motherboard for R121 (the pot) for easier connecting to your panel mounted DACT volume switch.
Thanks!
Is there a best socket and plug connector for that R121?
Old 16th January 2019, 02:36 PM   #1003
Any single or double row 0.1" (2.5mm) pitch connector will work. I used two rows of round pin PCB header.
Old 23rd January 2019, 10:37 PM   #1004
Added some heatsinks to the transistors.
Main board: R141 to 10k
THT: R10 33k, and R11 6k8.
Couldn't get the Vishay Metal film resistors, so found some other Metal film resistors, not as accurate as the Vishay's.
Still waiting for the DACT SMD attenuator.
The cable from the X121 to X111, how do I know what side is to be correct between them?
Old 23rd January 2019, 10:44 PM   #1005
Temp today outside will be at 46C degrees!!!
Old 24th January 2019, 06:25 AM   #1006
I checked on the circuit diagram when I built mine.
Old 24th January 2019, 06:25 AM   #1007
Done a bit more today.
Attached the AKSA to a timber board, attached the power board, found a previous LED cable, just need to know what resistor is needed for it. Put some PCB headers for the DACT attenuator (it's not here yet)
Just need to sort the power cable to the HP laptop power system, attach some RCA sockets and attach the DACT when it arrives and will see if it works!
Old 25th January 2019, 12:23 AM   #1008
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
For LED, 15k works well. Basically 45v and 15k gives 3mA which is not too blinding bright. 20k could work if you like a little but dimmer intensity.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 25th January 2019, 06:24 AM   #1009
It depends on the wavelength or color of the LED.
I've used 15k on the board plus an extra 56k in series (on the LED lead) to get a blue LED dim enough for night-time use. PSU is set to 48V.
Old 27th January 2019, 03:30 AM   #1010
Ok. have been waiting for the SMD DACT, and still hasn't arrived.
Have and set a Mouser potentiometer 10KOhms 688-RK09L12D0A1W, connected it today.
The pre-amp only works on the right side. Can feel the right side of the THT is warm on the heatsinks, and the the left side is cold.
How do I test where the left side is not connecting or some other mistake.
The sound on the right side sounds good, but if I turn the potentiometer up to the normal volume on my old Musical Fidelity Preamp 3A it crackles in the speaker.
AKSA's Lender Preamp with 40Vpp OutputHide this!Advertise here!
FS: AKSA GK-1 (EL) Preamp kit kv2 Swap Meet 1 14th April 2017 12:04 PM
Alternative output transistors for the Baby AKSA 55 cs Solid State 10 13th September 2013 11:06 AM
preamp for aksa 55 Professor smith AKSA 98 12th February 2012 01:11 AM
Borbely-Lender True Symmetry steph_tsf Solid State 33 23rd August 2011 01:52 PM
Aksa preamp? rick57 Solid State 11 19th May 2006 10:26 PM
Copyright ©1999-2019 diyAudio
