NE5534 buffer question
Joined 2002
Acc. to Douglas Self, ~22pF
Small Signal Audio Design: Douglas Self: 9780415709736: Amazon.com: Books
The NE5532/5534 opamp
The 5532 is a low-noise, low distortion bipolar dual opamp, with internal compensation for unity-gain stability. The 5534 is a single version internally compensated for gains down to three times, and an external compensation capacitor can be added for unity-gain stability; 22 pF is the usual value. The 5532 achieves unity-gain stability by having degeneration resistors in the emitter circuits of the input transistors, to reduce the open-loop gain, and this is why it is noisier than the 5534.
In 5532 TI datasheets, I can’t see emitter resistors though
http://www.ti.com/lit/ds/symlink/ne5532.pdf
http://www.ti.com/lit/ds/symlink/ne5534.pdf
George
