Hi, how are you all?
I have 2 of the velleman k1803: https://www.velleman.eu/downloads/0/illustrated/illustrated_assembly_manual_k1803_rev2.pdf
Can i replace the LM358 with a NE5532 to lower the noise or hiss without replacing any other component?
I'm powering one with 12v dc and the other one with 22v dc.
Yes but a TL072 would be even quieter according to the Ti data sheet; http://www.ti.com/lit/ds/symlink/tl072a.pdf
TL072 is the same case and pin out as 358 and 5532.
http://www.ti.com/lit/ds/symlink/lm158-n.pdf
I think the NE5532 will be quieter . The noise on the input buffer will be dominated by the 100K series resistor then the lower voltage noise of the NE5532 will excel in the second amplifying stage. Just put a 0.1uF ceramic capacitor across the voltage supply pins of the pcb board to assist stability ...........just my thoughts............try both and have a noise shoot out .
....velleman k1803.... lower the noise or hiss....
That design is TERRIBLE for low-hiss work.
Not the chip-- the 100K input resistor.
Find a different kit or roll your own.
That design is TERRIBLE for low-hiss work. Not the chip-- the 100K input resistor.
All four of the input 100k resistors can be reduced to 10k. The R1 and R6 values can remain as they are.
and yet we find that many claim the inverting topology is quieter than the non-inverting.That design is TERRIBLE for low-hiss work.
The 100k has ~40nV/rootHz compared to 4nV/rootHz of a 1k resistor.
If we assume opamp also has ~4nV/rootHz then the 1k combined with the inverting opamp will have ~ 5.6nV/rootHz and the 100k will increase the Ein to ~40.8nV/rootHz or about 17.2dB noisier compared to using a 1k input resistor.
+1 It's just not suitable for a low noise 40dB gain stage whilst keeping a reasonable input impedance.
(btw PRR - I am 'Newmarket' on the other forum)
- Analog Line Level
- Change or replace a LM358 with a NE5532
