Preamp suitability
Preamp suitability
Old 15th October 2017, 07:22 AM   #1
goodguys is offline goodguys  United Kingdom
Default Preamp suitability
Hi And thanks for reading.
I have a home theatre receiver, and am using the line-out bass output on the back of the amp to drive an active subwoofer.
The problem is the output from the amp is not enough and consequently i am not getting enough bass from the active sub.
I am thinking about getting a small preamp to boost the bass output from the reciever, have googled but am getting a lot of returns for phono cartridge turntable preamps, the nad pp-1.
What do you think, would this be suitable, i could turn the gain for the bass output right down on the reciever so hopefully would not overload the preamp input, but it says something about magnetic input on the preamp, so is this a stupid question in the first place.
Old 15th October 2017, 07:37 AM   #2
jazbo8 is offline jazbo8
jazbo8's Avatar
Preamp suitability
You do NOT want to use a phono preamp for the job. You want to get a line amp - a plain preamp. Did you try turning up the bass output (most likely in the setup menu) of the receiver?
Old 15th October 2017, 08:22 AM   #3
Mooly's Avatar
Preamp suitability
As above. A single opamp will do all you need configured as a simple gain stage.
You could also look at the receiver and sub circuit details and see if any easy way exists to change the output level or the gain (typically a resistor change).
Old 15th October 2017, 09:00 AM   #4
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
You could try something like this.
Douk Audio Single-ended Class A Pre-Amplifier HiFi Preamp Mini Board DIY KIT | eBay
Although the single op-amp solution is less complex you would have to find a way of fitting all the components together.
Old 15th October 2017, 11:58 AM   #5
gigigirl is offline gigigirl
Default An easier option to impliment
Hi you could also consider this option, it will work from a 12 to 24 VDC SMPS so would be a lot easier to install. Have used one myself for a similar application. Cheers
Electronics, Cars, Fashion, Collectibles, Coupons and More | eBay
Old 15th October 2017, 12:17 PM   #6
Once you start looking you will find plenty of options.
DC/AC 12v~15v Audio OP Preamps NE5532 AMP Hi-Fi Pre-Amplifier Board PHILPS | eBay
Old 16th October 2017, 05:12 AM   #7
Hi. Thanks for the replies.
I did turn up the bass output, unfortunatly the reciever i have is the arcam avr600 which is temperamental, there are quite a few reviews about this, and arcam's in-house design attempts.
I think after this arcam purchased a lot of their circuitry from analog devices.
When i turn up the bass it allows me a few db, but then anything over that all the other channels start dropping in volume. Strange amp, works well when it feels like it.
I will try out the preamps you have mentioned on ebay, is there a uk supplier for these as all the links are to china.
Old 16th October 2017, 11:45 AM   #8
nope, all the low prices are from China where they only pay 70p / hour for labour rates. cheers
Old 16th October 2017, 02:18 PM   #9
Mooly's Avatar
Preamp suitability
Assuming its a single mono preamp you need then something like this might be suitable.
Universal Mono Pre-Amp Kit - VELLEMAN KIT | CPC
Old 20th October 2017, 06:24 AM   #10
Looking at the velleman kit, is the marking af in /out meaning audio frequency in and audio frequency out? Where is the power supply in?
Preamp suitabilityHide this!Advertise here!
Phono Preamp PCB wanted - Transcendental Sound Grounded Grid Phono Preamp nathanjh13 Analogue Source 0 14th June 2012 10:19 AM
Magnetic-Pickup Phono Preamplifier renjiish Analogue Source 3 7th June 2010 05:01 PM
Passive Magnetic Preamp! Matthewong Tubes / Valves 8 4th September 2007 05:12 PM
suitability of LM833 for GC buffer/preamp mAJORD Chip Amps 10 28th April 2004 10:24 AM
