Sub Sonic Filter
Sub Sonic Filter
Old 19th July 2017, 10:13 AM   #11
Zero D is offline Zero D  United Kingdom
@ gigigirl
"Snell electronic cross-over" - What is the input impedance & output impedance/resistance ?
"Shue Class D base amp" - No idea what this is ! Did you mean Sure Class D Bass Amp ? Either way, What is the input impedance ?
The reason i need to know, is so the filter can be matched to the above
Rice Kellog still going strong Not sent from a SpyPhone with CrapApps etc
Old 20th July 2017, 04:28 AM   #12
gigigirl is offline gigigirl
Sorry absolutely no idea
Old 20th July 2017, 05:11 AM   #13
Gopher is offline Gopher  United Kingdom
Ever heard of Google? It can be found on t'Interweb.
Old 20th July 2017, 05:55 AM   #14
Sorry, completely over my head
Old 20th July 2017, 07:17 AM   #15
@ gigigirl
Don't worry, the info should be in the manuals etc, if you have them ? If not, try to obtain them from the vendors etc
Old 20th July 2017, 07:47 AM   #16
Grasso789 is offline Grasso789  Germany
Regarding turn-over f and steepness, i use power amps with built-in 1st-order 15 Hz hi-pass, have another such hi-pass in place at line-level and yet another one archieved by negative feed-back of the phono preamp. I want to mostly tame play-back of vinyl, which has been warped by exposition to sunlight, and drop level of fundamental pick-up resonance but also grind the edge off bass-exploitation CDs.
Old 20th July 2017, 09:21 AM   #17
dotneck335 is offline dotneck335  United States
Rod Elliot's subsonic filter would do nicely:
Project 99 - Subsonic Filter
Old 21st July 2017, 11:28 PM   #18
Default Now that I can build
Thanks Dockneck, That i can build & it also gives me the ability to tayloy the cut off slope to my need in my room. Thanks guys for all your patience & help.
Cheers
Old 21st July 2019, 03:42 AM   #19
Naddiarts is offline Naddiarts
Smile Diy subsonic filter
Hi. My name is Nadia. I am from Buenos Aires Argentina. I need a subsonic filter to put in my phono imput in my sintoamplifier Yamaha RV595A. I got a JVC quartz turntable QL-F4. I got a lot of rumbo e incluso my speakers. I do not want to break them.
I saw a couple of filters (one for each channel) in u$s 22 plus shipping. But in my country is very difficult to receive any foreign product these days.
I need to do them myself. I can buy down here the rca males and fe males and the caps but i don't know which valiente to buy. I'll be very happy if Anyone can tell me which caps to buy and how to assembly the filter.
I excuse me for my english is not good enough..
Regards.
Old 24th July 2019, 05:15 PM   #20
EmuMannen is offline EmuMannen  Sweden
I use Rods P99 and it works great.
Sub Sonic FilterHide this!Advertise here!
The ultimate rumble filter - far more effective than just a high pass filter! monty78pig Analogue Source 65 17th August 2019 04:51 PM
6c45pi : sonic utopia or sonic hell? Kashmire Tubes / Valves 30 25th November 2012 01:00 PM
Sub Sonic Filter Wild Willy Analogue Source 3 29th April 2011 01:54 AM
bi-amping with sonic impact t amp/using sonic impact amp for headphones jon_m Class D 3 16th February 2006 10:16 AM
chassis-mounted filter or IEC plug filter jarthel Solid State 7 11th March 2002 10:17 AM
Copyright ©1999-2019 diyAudio
