Salas DCG3 preamp (line & headphone)
Old 26th November 2016, 09:45 PM   #601
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Hikari1 View Post
Got my jfets today. Any reason to be concerned about fakes?
There wasn't any real demand for those so the fakers to target them, the packaging is unusual to readily have for faking anyway, and the letters look old school in your photo so I would not easily worry. If you can trace them I had posted their curves to compare. What Idss they got? All of my samples show very near Idss between their sections.
Old 27th November 2016, 12:16 AM   #602
Hikari1 is offline Hikari1  United States
I have no reason to believe they are fakes and I haven't tested them for idss yet. Waiting on my boards to get serious about building this thing. I don't have a curve tracer but once I test for idss I will post it.
Old 27th November 2016, 08:49 AM   #603
R.I.P.
the cheap and easy way to test Idss is to use a 9V battery, a 100r resistor and a DMM voltmeter.
Short the Source and Gate leadouts together with a croc clip and lead.
Connect this G+S to battery negative.
Use a second lead to the 100r resistor.
Use a third lead from resistor to Drain leadout.
Measure the voltage drop across the 100r.
BTW,
the different batch codes probably indicate you have genuine devices.
regards Andrew T.
Old 27th November 2016, 03:33 PM   #604
nashbap is offline nashbap  United States
Salas, can one substitute a different Mosfet for M1? Perhaps the Toshiba 2SJ313?
Thanks. nash
F5TV3, AVC, BA3b pre, Salas DCG3b, OBL-15
Old 27th November 2016, 03:43 PM   #605
Salas's Avatar
No, its too sensitive for such substitutions regarding performance. It was showing substantially more THD even with Fairchild FQP3P20.
Old 27th November 2016, 03:47 PM   #606
Ok Thanks.
Old 28th November 2016, 08:14 PM   #607
Theodosis O. is offline Theodosis O.  Greece
Hi Salas,
can one substitute bigger capacitors for C6, C7 ?
i.e. 330 uF
Old 28th November 2016, 08:55 PM   #608
Salas's Avatar
Probably but I haven't tested more than 100uF
Old 1st December 2016, 05:02 PM   #609
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Default Mambo double Polish donuts, classA big sound this evening folk's
So...
Thread is waiting for people recieving theyr'e pcb and part's i guess
Meanwhile mine is cooking on hifi...
15-20min. for best sound IMHO, then everything is around 30-35C. hot.
AKG's headphone are addicting, why do i keep my speaker's ... Well they sound marvelous too on this combo.
This little big classA preamp. is having only few hours on it, and allready sounding very very good.
Nothing more, just wanna showoff
Jesper.
DCG3 Dual DCSTB, R2R DAC in build (2 ReflectorD's (+5VDC/+3.3VDC) + SSLV1.1 (+/-12VDC))
AlephJ Mimi! http://www.diyaudio.com/forums/pass-...mimi-mini.html
Old 1st December 2016, 05:21 PM   #610
Salas's Avatar
Hardcore DIY boards, great pictures, and a nice forerunner adventure for the industrial boards builders to have seen. Congratulations for your work. You even confirm the pdf guide words "Due to class A operation its not being a cold idling circuit so some warm up time is recommended before critical listening". Nice that you like the AKG K240 recommendation also. Difficult for me to try suggest solutions as subjective as choosing transducers and not disappoint. Do you hear some positive differences now that you run it on proper double mono Tx execution?
Salas DCG3 preamp (line & headphone)Hide this!Advertise here!
FS: Pass VFET 2 essential+supplemental kit and Salas DCG3 kit 32y0 Swap Meet 3 16th April 2018 05:22 AM
FS : Salas DCG3 pinnocchio Swap Meet 2 9th January 2018 10:32 PM
FS: 2x Salas DCG3 and DCSTB complete kits bvtrinh Swap Meet 5 26th October 2017 11:29 PM
WTB Salas DCG3 pcb or kit savvas Swap Meet 0 8th February 2017 10:50 AM
Using a line preamp to drive headphone ginetto61 Solid State 25 6th May 2015 06:19 PM
Copyright ©1999-2019 diyAudio
