Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Thread Tools |
#5121 | ||
diyAudio Chief Moderator
Good ones are also the KOA Speer MF series. Not too expensive. |
#5122 |
I use CMF resistors because they are non magnetic. Many resistors have steel end caps which is supposedly not good for audio.
#5123 | |
I have used Vishay Beyschlag MBB and MRS series for R1. You can parallel upto 3 on these boards. Since these are 0.6w each you can make 1.8w with three of them or 1.2w with two in parallel. 50ppm and inexpensive. nash
F5TV3, AVC, BA3b pre, Salas DCG3b, OBL-15, SonyVfet2pair monos, Millett Nutube Bal pre |
#5124 |
If you guys are willing to use single but the exact (or very close) values and do not mind to use bit excessive power rating, then partsconnexion still sale MRA-5s. They are the bests for such positions, but unfortunately they are not cheap.
Mills MRA-5 Resistors |
#5125 | |
On the other side I have yet to come across a magnetic RN. Mouser have a good stock of high quality 1W/2W resistors, most other places don't. For Europe Hificollective has some 2W Kiwame, 1W PRP (both 10R +) and 1W Takman metal films (2R2+). For America PartConnexion has more variety of audio resistors. My preference is CFP series for their relative small size and good specs. Welwyn W21 (3W) has also compact size (Farnell has them) DCG3 / FSP / UFSP has some limitations for power resistors size but BIB / UBIB are more flexible so 3W/5W can be used. |
#5126 |
Thanks, Guys! If there's no measurable difference, then KOA Speer is my choice, and I'll have few extra dollars for a nice enclosure
#5127 |
They came..
![]() ![]() Thank you so much Mike
Titan 2000 ,Cressendo Millenium 2000, P3A ,VSSA ΤΟ3 ,B1 Buffer ,Golmund Mimesis 9.2 Clone , Dispre 2 - JFET, DCB1, Buffalo II,, Arduino LDR Volume, AK4490 Discrete Mirand Audio, 6V6 Salas Preamp. USSA-5. Salas DCG3 |
#5128 |
Αnd little progress.....
#5129 |
#5130 |
You were quick, are you gonna make A/B comparison with the transistors/jfets, I see bases in place of mirror transistors.
Good parts, it's only I don't like PRP resistors, FGs just fitted. What psu you gonna use? |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
FS: Pass VFET 2 essential+supplemental kit and Salas DCG3 kit | 32y0 | Swap Meet | 3 | 16th April 2018 06:22 AM |
FS : Salas DCG3 | pinnocchio | Swap Meet | 2 | 9th January 2018 11:32 PM |
FS: 2x Salas DCG3 and DCSTB complete kits | bvtrinh | Swap Meet | 5 | 27th October 2017 12:29 AM |
WTB Salas DCG3 pcb or kit | savvas | Swap Meet | 0 | 8th February 2017 11:50 AM |
Using a line preamp to drive headphone | ginetto61 | Solid State | 25 | 6th May 2015 07:19 PM |
New To Site? | Need Help? |
