Salas DCG3 preamp (line & headphone)
Old 5th December 2019, 03:01 PM   #4261
bubba177 is offline bubba177  United States
I could use just the F4 and drop the voltage gain to zero ( lol ) I have no doubt this thing will drive it fine. My jet boz does. right now I set the pot at halfway point and use remote control on CD player. Your 6v6 pre and the F4 are a great match
Old 5th December 2019, 05:04 PM   #4262
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Yep, there are ways
Old 6th December 2019, 06:12 PM   #4263
2X DCG3 with just the F4 is perfect for my system. Can't wait for TKD to get here!
Old 6th December 2019, 06:51 PM   #4264
Salas's Avatar
You have better hand on the pot and even better background details with this system gain structure I suppose?
Old 6th December 2019, 11:05 PM   #4265
katopis is offline katopis  Greece
I am sure it is dcg3 is a wonderful preamplifier,and i have listened a lot!i build another one for the my second system...
Old 8th December 2019, 03:51 AM   #4266
Salas's Avatar
I examined the 2CP-2511 TKD 20k model. It measures 18k across and has 4.5k Zo at the 1/2 signal division point. Derived from output signal level drop when applying known loads.
For all intents and purposes its nominal value should be chosen for replacing same nominal value series pots. Because a series has max Zo a quarter of its Zin.
A series would not max out anywhere else than at the 1/2 division point. The TKD Zo also shows 6.3k at 1/4 and 4k at 3/4 division. Its an own kind of pot. But the Zo range is compatible enough.
Old 8th December 2019, 04:19 AM   #4267
dewdrop is online now dewdrop  Singapore
So if we have access to all the TKD pots, which one should we buy? Now thinking about changing my Alps blue pot.
Old 8th December 2019, 04:25 AM   #4268
Salas's Avatar
20k TKD for replacing 20k Alps.
Old 8th December 2019, 04:29 AM   #4269
Salas's Avatar
If only the 10k TKD is available (and if you don't like the tonal balance with it) add 2.2k good quality resistor in series from wiper (pin 2) to the DCG3's input.
Old 8th December 2019, 02:18 PM   #4270
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
I have TKD pots on my balanced DCG3 unit..... much better SQ than with previous ALPS blue.
Higher overall definition without a hint of edginess I sometimes find with discrete pots made of metal resistors...
RC
Salas DCG3 preamp (line & headphone)Hide this!Advertise here!
FS: Pass VFET 2 essential+supplemental kit and Salas DCG3 kit 32y0 Swap Meet 3 16th April 2018 06:22 AM
FS : Salas DCG3 pinnocchio Swap Meet 2 9th January 2018 11:32 PM
FS: 2x Salas DCG3 and DCSTB complete kits bvtrinh Swap Meet 5 27th October 2017 12:29 AM
WTB Salas DCG3 pcb or kit savvas Swap Meet 0 8th February 2017 11:50 AM
Using a line preamp to drive headphone ginetto61 Solid State 25 6th May 2015 07:19 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
