Salas DCG3 preamp (line & headphone)
Salas DCG3 preamp (line & headphone) Please consider donating to help us continue to serve you.
Old 22nd November 2019, 01:19 PM   #4171
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
You are looking for system synergy details. You have to experience pot Zo differentiation in situ for yourself. My recommendation is try the other options as well. 327s and 2SK170s with series or shunt PSUs. L-Adapter stacked positives are yet another option. A powerful little PSU. It may give the sense you are after with its high Amperage series pass transistor and hi-cap reservoirs.
Old 22nd November 2019, 01:30 PM   #4172
Salas's Avatar
Originally Posted by savvas View Post
My opinion is that although new generation DAC is used, it's still gives a touch of that opa-sound which I'm not fan of.
OPA based for its output circuit indeed if I remember correctly.
Old 22nd November 2019, 01:58 PM   #4173
Theodosis O. is online now Theodosis O.  Greece
No, for DCG3 I have Panasonic FC. In other circuits I've tried them for local decoupling they open up the soundstage with lots of details. Usually I use them in digital stuff, let's say for special purposes.
After many tests, I found Organic Polymer far more dynamic. More energy.
Old 22nd November 2019, 07:22 PM   #4174
nashbap is offline nashbap  United States
Hi Salas,
You mention that the new boards have split grounds. Why was this done? Also, you had suggested in the past that the ground could be cut. Could you point out where?
Thanks.
nash
F5TV3, AVC, BA3b pre, Salas DCG3b, OBL-15, SonyVfet2pair monos
Old 22nd November 2019, 10:30 PM   #4175
savvas is offline savvas  Greece
I've already tried DCSTB, BIB and UBIB, each with its own sound character. My transformers and not CT so L-Adapter could also be tried although I'm expecting they won't deviate much from DCSTB.
As for pot Zo one option is to buy one or two cheap chinese DACT-clone pots and experiment with different Zo. The biggest problem upgrading my relay-based is finding better spected resistors (i.e. the right values). If I have hard time finding suitable values I'm gonna try Muses solution, it's output resistance is between 1K5 and 6K5.
Thanks Theodosis, I have another DCG3 for the making indented for balanced and A/B part testing so I could try this along with other things .
Old 23rd November 2019, 12:01 AM   #4176
Salas's Avatar
Originally Posted by nashbap View Post
Hi Salas,
Thanks.
nash
For flexibility in grounding schemes. A gap can be bridged when a lane can only be cut so better have a gap I thought. Thus I added that feature. Don't cut a classic board except there's a ground loop in a certain system and you need to try alternatives. Which is not that likely since buzz free classic board builds playing in various systems are so many here.
Old 23rd November 2019, 03:36 AM   #4177
Thanks. Nash
Old 23rd November 2019, 03:57 AM   #4178
My opinion is that although new generation DAC is used, it's still gives a touch of that opa-sound which I'm not fan of. That being said, my new amp make this shortcoming less obvious. It's quite enjoyable, not tiring at all but not my cup of coffee
I don't want it and neither DCG3 does sound 'balsie' but I'm fan of dynamic sound and that could be improved if I bring my attenuator to DCG3's recommended specs. So is it better to have constant 6.25K or 5K output resistance for attenuator ?
I don't expect big changes and there are other things to play with: I have yet to test BC327s, LSK JFet, etc. The new amp push them back but now tweaking time has come.
Hi Savvas,
Let me suggest another way to address your attenuators question.
Most of us here are serious listeners and do most of our listening in a certain db range. With my dcg3 my normal level is -27db pot attenuation, going down to about -31 and louder to about -19 db. In my case -27db is with 20k and .909k resistors for a pot value of 20.9k. Measure your present pot at your most listened position, then use resistor combinations to achieve that and choose what sounds best. Better still build your own like I do with your favorite resistors.
Nash
Old 23rd November 2019, 11:54 AM   #4179
Hi Savvas,
Nash
That's nice solution especially if you are on a budget but you don't want to cut corners.
The problem is that remote is a must for me and this is very costly for switching resistor type of attenuators. Relay-based ones are most cost-effective solution with small number of resistors but with weird values (so those exotic type of resistors can't be used)
Aiming at Dale PTF or something similar otherwise compromise has to be made or simply finish the psu for Muse.
I want to settle with the attenuator thing and then start other tweaks.
Old 23rd November 2019, 02:57 PM   #4180
You could be happy with a stepper motor driven stepped attenuator.
nash
Salas DCG3 preamp (line & headphone)Hide this!Advertise here!
FS: Pass VFET 2 essential+supplemental kit and Salas DCG3 kit 32y0 Swap Meet 3 16th April 2018 06:22 AM
FS : Salas DCG3 pinnocchio Swap Meet 2 9th January 2018 11:32 PM
FS: 2x Salas DCG3 and DCSTB complete kits bvtrinh Swap Meet 5 27th October 2017 12:29 AM
WTB Salas DCG3 pcb or kit savvas Swap Meet 0 8th February 2017 11:50 AM
Using a line preamp to drive headphone ginetto61 Solid State 25 6th May 2015 07:19 PM
Copyright ©1999-2019 diyAudio
