Salas DCG3 preamp (line & headphone)
Old 29th May 2019, 08:00 PM   #3841
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by shattered_dream View Post
Hmmm what would you recommend... The Bc560 or the Bc327-40?
I'm not sure until now.... Since there were both in my package
Originally Posted by vgeorge View Post
Better use BC-327-40
Originally Posted by beardman View Post
I have tried BC-327-40 2 times
but prefer in my setup BC560
so try both and listen carefully,,,,BC 327 is more mellow here
In most builders feedback BC327 was the preference. Usually described as more resolved in the upper bass and softer in the highs. That's not excluding the BC560's more upfront result suiting some system better. I recommend female mounting pins for easy exchange and evaluation.
Old 29th May 2019, 08:33 PM   #3842
bambadoo is online now bambadoo  Norway
Finally did the BC327 mod. Have not tested the unit yet. Some more work is in progress
Like moving the headphone connection to the front of the amp. And adding muses 72320 volume control for the fun of it.
It take its time
Old 29th May 2019, 08:36 PM   #3843
shattered_dream is offline shattered_dream  Germany
Hmmm could this be the pins that are included in the full kit package?
Old 29th May 2019, 09:05 PM   #3844
Salas's Avatar
Are they female type pins like those found in an op-amp socket?
Old 29th May 2019, 09:16 PM   #3845
Yeah think so
Old 29th May 2019, 09:39 PM   #3846
Salas's Avatar
Fine, those are the ones. Use them in triplets for transistors. Don't cut them down to single units because they will not be easy to handle and solder on the PCB.
Old 4th June 2019, 05:08 AM   #3847
AnthonyA is offline AnthonyA
Hi Salas
What can i do for balanced input?
Old 4th June 2019, 06:56 PM   #3848
Salas's Avatar
Something like that: A Low Power, Low Cost, Differential Input to a Single-Ended Output Amplifier | Analog Devices
Or a line balancing transformer used the other way around.
Through such solutions you can drive a single ended input circuit from a differential source.
To build a balanced preamp takes four channels to use them as two phases per channel.
Salas DCG3 preamp (line & headphone)Hide this!Advertise here!
FS: Pass VFET 2 essential+supplemental kit and Salas DCG3 kit 32y0 Swap Meet 3 16th April 2018 05:22 AM
FS : Salas DCG3 pinnocchio Swap Meet 2 9th January 2018 10:32 PM
FS: 2x Salas DCG3 and DCSTB complete kits bvtrinh Swap Meet 5 26th October 2017 11:29 PM
WTB Salas DCG3 pcb or kit savvas Swap Meet 0 8th February 2017 10:50 AM
Using a line preamp to drive headphone ginetto61 Solid State 25 6th May 2015 06:19 PM
Copyright ©1999-2019 diyAudio
