Salas DCG3 preamp (line & headphone)
Old 16th May 2019, 07:01 PM   #3831
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
I believe 500R is lowest possible value. My lazy man test would be to put another 1K on R6 to get to 500R to see. Salas would have to validate that is lowest possible value.
Salas Boards GB 2019 #1 CLOSED boards On Order | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 16th May 2019, 07:03 PM   #3832
Joschl is offline Joschl  Germany
Joschl's Avatar
You can hang a resistor from the source input to the potentiometer input. Choose R same as volume potentiometer. This creates sort of a virtual potentiometer with double the input resistance and only half way can be put out via the wiper ( middle pin). The virtual pot turns only half while your knob turns full. And easily reversible tooSalas DCG3 preamp (line & headphone)
Old 16th May 2019, 09:55 PM   #3833
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by killie99 View Post
I now have the DCG3 hooked up to my main system, it’s super quiet, not a bit of hiss or hum from the speakers. I do however have a pretty major problem, I have just got waaaaaaaaaaayyyyyyyyyyyyy too much gain! I’m currently using just the power amp section of my Perreaux Eloquence 250i and I can use to about 8 o’clock on the pot and it’s very loud. Checked the manual and I have 28.8dB of gain in the power amp - how low can I take the gain on the dcg3 (currently set to 3 with a 1k) without causing any issues?. Long term plan is to get a different amp but what’s the best approach to reduce the gain in the time being?
Although an input voltage divider is possible, it's better to fix the gain lower via R6. Not to narrow the bandwidth with inevitably higher source impedance. Since this circuit isn't input buffered. Can go down to 500R R6 as mentioned. The amplifier's gain is high enough, maybe the speakers are sensitive enough also? Anyways, when in a loud combination the background is still reported quiet after adding 3x, that surely points to a good preamp build.
Old 16th May 2019, 10:07 PM   #3834
killie99 is offline killie99
I'll try and source some Dale 499 ohm in the UK to lower the gain. A quick google pops these up, Salas can you confirm these are what I need? Vishay Dale CMF55 resistor 1% 50ppm 499ohm - Audiophonics
I also have 4 BC327-40 all with 499-502 hfe so I'll pop them in as well.
Old 16th May 2019, 10:17 PM   #3835
Salas's Avatar
Those resistors are fine, same as the kit's others. That change will bring your gain down to 2/3 of what's now. You will probably like the alternative current mirror transistors too.
Old 19th May 2019, 09:24 AM   #3836
shattered_dream is offline shattered_dream  Germany
Hmmm do I need insulation foil for the heat sink of the dcstb?
Old 19th May 2019, 12:58 PM   #3837
Salas's Avatar
You need insulation pads and insulation grommets for each MOSFET to that sink. The sink itself can be fixed non insulated to the chassis.
Old 29th May 2019, 06:07 PM   #3838
Hmmm what would you recommend... The Bc560 or the Bc327-40?
I'm not sure until now.... Since there were both in my package
Old 29th May 2019, 06:58 PM   #3839
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Better use BC-327-40
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 29th May 2019, 07:18 PM   #3840
beardman is offline beardman  Denmark
I have tried BC-327-40 2 times
but prefer in my setup BC560
so try both and listen carefully,,,,BC 327 is more mellow here
Salas DCG3 preamp (line & headphone)Hide this!Advertise here!
FS: Pass VFET 2 essential+supplemental kit and Salas DCG3 kit 32y0 Swap Meet 3 16th April 2018 05:22 AM
FS : Salas DCG3 pinnocchio Swap Meet 2 9th January 2018 10:32 PM
FS: 2x Salas DCG3 and DCSTB complete kits bvtrinh Swap Meet 5 26th October 2017 11:29 PM
WTB Salas DCG3 pcb or kit savvas Swap Meet 0 8th February 2017 10:50 AM
Using a line preamp to drive headphone ginetto61 Solid State 25 6th May 2015 06:19 PM
Copyright ©1999-2019 diyAudio
